FrameFuji...X-fusion Team Superlite
Front ForkFuji Liteweight Full Carbon
Bottom BracketAmerican Classic ISIS, 108MM
CranksFSA Carbon Pro Team w/ISIS sline
ChainringsCNC 34/50 Chainrings
PedalsWelgo M-7
Front DerailleurDura-Ace
ChainDura-Ace
Rear DerailleurDura-Ace
CogsetDura-Ace
HubsVelomax (patented)
SkewersVelomax (patented)
SpokesVelomax (patented)
RimsVelomax Ascent II's
TubesContinental Race Lites
TiresContinental Attack(f) & Force(r)
BrakesDura-Ace
SeatpostITM Millenium Carbon
SaddleSelle Italia Prolink Gel
HeadsetIntegrated Road, with convex hollow alloy 25mm spacer
StemITM Millenium Carbon
HandlebarsITM Millenium Carbon
ShiftersDura-Ace STI
Brake LeversDura-Ace STI
Bar TapeHaven't found that perfect bar tape yet.
ExtrasSigma BC-1200 Computer
Joey Jones from Jacksonville, FL writes:
This is my bike...minus the ITM Millenium Carbon cockpit, which I'm now working on. I specked the bike this way to be extreamely lite yet strong at the same time. I'm 220lbs with legs and bunz of steel so I need something that can take the abuse without giving. The Fuji Team Superlite is one of the lightest production bikes around weing in at just under 16lbs for the 56cm out of the box. After I finish up with the ITM Carbon cockpit I should have a sub 15lbs. flash. Will you be able to stand the rain...expecially if you spent twice as much on your bike. Total investent at this time is $1400 before the cockpit upgrade. After that, I should have about $1700 in the bike. Anyone what to ride just let me know.
BACK to the Dream Bikes Section
Ridley:
Ritchey :
