Framecarbon
Front Forkcarbon
Bottom Brackettitanium
Crankscarbon
Chainringscarbon
Pedalslook
Front Derailleurnone
Chainnone
Rear Derailleurnone
Cogsetnone
Hubsbontrager modified
Skewersbonty
Spokesnone
RimsHED aero disc
Tubesvittoria
Tiresvittoria
Brakeszero
Seatpostanatomically curved carbon
Saddlenone!
Headsetnone
Stemcarbon
Handlebarsnone!
Shiftersnone
Brake Leversflaight deck
Bar Tapenone
Extrasanal lube
doug poon from westfield nj writes:
The cap has become a reality! although the second generation is lighter, stiffer and faster than the first, and the seatpost shape is modified to conform more to the innards of the rectum since it is now bullnosed with a smoother taper and curved, there have even been some pleasure nubs and ridges added for that extra thrill! Also the lube is now pressure distributed through a series of orifices that are radially drilled towards the tip of the post, and it operates on a pump principal every time there is vertical movement in the "Saddle". This is the sickest ride, so fast and nible, and its awesome for breaking away from the peloton, and if your into being a real velo type of man, then go off road with it over some curbs, or try taking on a speed bump. Next generation of the cap will have a power tap hub on board to monitor and diagnose performance. Stay tuned
BACK to the Dream Bikes Section
Selle Italia:
Kestrel 2011:
