Dream Bike
Frame61 cm Cervelo P3 (for road use - yes, trust me)
Front ForkCervelo Chord or Wolf
Bottom BracketPhil Wood Mag Ti - not so sure, but probably
CranksRotorbike RCK 205mm (Powercranks for training)
ChainringsDura-Ace 56-44 (TT/Tri rings, but will work here)
PedalsSpeedplay X/1 w/ BTP kit
Front Derailleur2004 Dura-Ace
Chain2004 Dura-Ace
Rear Derailleur2004 Dura-Ace
CogsetCycle Dynamics 11-21, 12-26 depending, TiN coated by Poshbikes, or Dura-Ace
Rimswheels - Zipp Z4
TiresContinental Tempo or Dugast Strada CX silk (19mm front, 22mm rear)
Brakes2004 Dura Ace or Cat Claws *prob. Dura-Ace - front brake and stem bolts/faceplate are two areas where you want true reliability)
SeatpostCervelo carbon aero (actually aero, true NACA profile)
SaddleBrooks Swift or Fizik Arione or SaddleCo Flow
Headsetintegrated w/ frame
Stemstruggling with this one - new Thomson? 3T Zepp XL?
HandlebarsDeda Newton shallow "Italian" drop 42 cm
Shifters2004 Dura-Ace
Brake Levers2004 Dura-Ace
Bar TapeOff-the-front, thin but thicker right above the hoods)
ExtrasM2Racer Power Module
A. H. Meador from abc writes:
French maid guy is a real perv... Peter's Parlee Z1 is fantastic, but overall will get stomped by it's inefficient aerodynamics (typically-shaped frame, though excellent in all other ways, and ADA wheels are in reality not all they're cracked up to be - but they are light and they're coming out with an 800g wheelset!). Greg Powell has two stems, a concrete slab of a "saddle," wheels that don't exist, pedals that are still prototypes and the wavering Q-factor is quite inefficient, and the free float is not enough), a dangerous seatpost, heavy and uncomfortable tape, and wheels that don't exist - you mean 58mm depth). M2Racer Power Module is for adjusting saddle forward for climbs (I know convential wisdom says the opposite, but think about it objectively long and hard) and is removeable when not desired.
BACK to the Dream Bikes Section
Hot Deals See all the Hot Deals Here >>
Giro Helmet 2011
Saros Livestrong
$75.00 40% off
$125.00 msrp
JensonUSA
ROL Wheels
RACE SL
Sale $625.00+shipping
4.92 out of 5
ROL Wheels
Reviews and Featured Articles
Advertise With Us | About Us | Contact Us | Privacy Policy | Terms Of Use The ConsumerREVIEW.com Network
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2012 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
