American Classic Argent Disc Tubeless wheels review
Durable alloy wheelset ready for road, cyclocross or gravel (ab)use
Wheels
Exploring new heights was elemental to this test session. That's Mt. Crested Butte in the center of the background.
Exploring new heights was elemental to this test session. That’s Mt. Crested Butte in the center of the background.
Lowdown: American Classic Argent Disc Tubeless Wheels
The goal for this test: See if we could break these wheels — or at least wreck a little havoc on the tires. The testing ground: All manner of bad dirt roads (4×4, jeep, rocky, double and singletrack, you name it) that crisscross the hills and mountains that surround our Colorado test HQ in Crested Butte. End result? Read on to find out.
Stat Box
Depth: 30mm Spoke count: 24 front and rear
Outer rim width: 22mm Spoke lacing: 2-cross
Inner rim width: 19.4mm Claimed weight: 1531g
Front hub: American Classic Disc 130 Actual front wheel weight: 750g
Rear hub: American Classic Disc 225 Actual rear wheel weight: 840g
Hub engagement: Six pawl cam actuated system Total actual weight: 1590g
Front axle: QR or 9mm, 12mm or 15mm thru-axle Extras: Tubeless tape and tubeless valves included
Rear axle: QR, 10x135mm or 12x142mm thru-axle Tested tires: Clement X’Plor MSO 700c x 36
Driver: Shimano 10/11, Campy 10/11, SRAM XD Wheelset price: $1149
Brake interface: Center Lock, 6-bolt kit included Rating: 4 Stars 4 out of 5 stars
Spokes: American Classic bladed black
Pluses
Minuses
  • Tubes not needed
  • Road tubeless tires required for tubeless set-up
  • Tubeless tape pre-installed
  • Some initial overnight air leakage
  • Tubeless valves included
  • Adapter needed for 6-bolt rotors
  • Wide inner rim width
  • Simple (bordering on boring) aesthetics
  • Can run lower pressure
  • Over $1000 for alloy rims
  • Lower rolling resistance
  • No burping during testing
  • No flats during testing
  • Easy tubeless set-up
  • Relatively light wheelset
  • Stiff and durable wheelset
  • Aero-enhancing profile
  • Steel faced cassette body prolongs hub life
  • Changing cassettes easier
  • Quick engaging hubs
  • Purring free hub
  • 17mm axle maintains hub bearing alignment
Review: American Classic Argent Disc Tubeless Wheels
Like any tubeless wheelset test, the initial challenge starts in the workshop where you find out how big a pain in the ass it is to set them up sans tubes. The answer for American Classic’s flagship Argent Disc Tubeless road wheels was very little pain.
The American Classic Argent Disc wheels can do triple duty as a road, CX or gravel road conduit.
In took a little tugging to get our test set of Clement X’Plor MSO 700×36 tubeless ready tires onto the rims, but once mounted the beads quickly snapped into place with just a floor pump. From there the included tubeless valves with removable valve cores made it easy to squirt in the requisite amount of Stan’s NoTubes sealant. The rims even come pre-taped.
Initially we had some overnight air leakage in the front (but not the rear). However, after a month or so of testing, we pulled both tires and topped off sealant. Leakage has subsequently ceased.
These wide rims plumped up the Clement X'Plor MSO 36mm tires to 37.5mm. MSO is the airport code for Missoula, Montana, which appropriately is home to the Adventure Cycling Association.
These wide rims plumped up the Clement X’Plor MSO 36mm tires to 37.5mm. MSO is the airport code for Missoula, Montana, which appropriately is home to the Adventure Cycling Association.
The tires, though listed at 36mm, plumped up to 37.5mm wide when inflated to 50psi. That’s a testament to the Argent’s generous 19.4mm inner rim width. The net effect was a generally cushy, smooth rolling ride with plenty of confidence-enhancing traction in loose terrain, which is where the MSO’s (Missoula, Montana’s airport code) are most at home. Indeed, the tire’s label says they are designed for adventure, with soft rubber for extra grip, plus a puncture protection belt under the tread. We definitely did some adventuring — and suffered no flats.
On the Road Less Traveled
There’s a reason the Crested Butte area is known for its mountain biking rather than road riding. While there are some 750 miles of sweet serpentine singletrack in greater Gunnison County, you can count the number of quality paved road rides on one hand. That doesn’t mean drop bar bikes have no place here. You just need a set-up that doesn’t mind getting a little dirty.
The slightly rounded 30mm deep rims have subtle aero shaping.
That’s just what we had for this test: Van Dessel Full Tilt Boogie ’cross frame, SRAM Force 1x drivetrain with hydraulic disc brakes, and the American Classic Argent’s wrapped in Clement tubeless-ready rubber. It was an ideal package for exploring the area’s well- and rarely-traveled dirt roads.
Continue to page 2 for more on the American Classic Argent Disc Tubeless wheels
