Dura-Ace 9000 Loses Weight, Features Improved Ergonomics, More Distinctive Shift Feel, Improved Braking
Dura-Ace 9000 gets lighter, more ergonomic and brings the feel of Dura-Ace Di2 to the mechanical realm.
Dura-Ace Di2 represents the pinnacle of Shimano's road component group technology. That's why the ten World Tour-level teams who ride Shimano overwhelmingly use Dura-Ace Di2. But for those who abhor batteries or don't way to lay out the cash for Di2, the Dura-Ace 9000 groupset offers many of the ergonomic, braking and shifting performance-enhancements designed into Di2 in a cable-actuated, mechanical format. In a future piece, we'll take a look at how Dura-Ace 9000 performs on the road.
For now, to find out what's new, improved and evolved in the DA 9000 groupset, we unboxed and built up a complete DA 9000 group set. Then we spoke at length with Dave Lawrence, Shimano's road product manager and Dura-Ace guru. Here's what we found out.
More Affordable, Lighter
The previous iteration of Dura-Ace mechanical (minus wheels and pedals) cost slightly less than $2,700. The new DA 9000 costs $2494.92 (again, minus wheels and pedals), the consequence of a more favorable exchange rate, according to Lawrence. While 35 grams heavier than a complete Di2 groupset with an internal battery due to the weight of cables and housing, DA 9000 weighs 77 grams less than its DA 7900 predecessor.
The brifters have been redesigned to optimize ergonomics and improve braking, shifting and comfort from the hoods.
Improved Ergonomics
When Shimano engineers designed the brifters for DA Di2, they had the luxury of focusing primarily on ergonomics since they didn't have to worry about how to house the intricacies of a mechanical shifting system inside. The learnings from designing the Di2 brifters have been applied to the new, refined DA 9000 brifters which somehow DO fit everything needed to operate a mechanical system into a brifter that evolves the ergonomic shape of the Di2 brifter.
The shape has been designed to perform well from the drops, but also with much consideration towards the hoods, where many riders, and even racers, seem to be spending more time on modern bike designs. "We tried to really make sure the braking and shifting feels as good from the hoods as it does from the drops," says Lawrence.
Coated Cables, New Brake/Derailleur Designs
To achieve that design goal and further refine shifting and braking performance over the previous DA 7900 mechanical group, Shimano designed new polymer-coated cables for the DA 9000 groupset and made changes to the brake and derailleur designs. The polymer-coated cables decrease friction for smoother braking and shifting action. But they're so slippery that they should only be used with DA 9000 because clamping mechanisms on other groupsets haven't been designed for them.
Continue reading for more on the Dura-Ace 9000 and full photo gallery.
An entirely new front derailleur design strives to bring the feel of Di2 front shifting to mechanical Dura-Ace.
Font Derailleur
The completely new DA 9000 front derailleur has been designed to mimic the feel and trim options found in the Di2 front derailleur. "We added a trim stop position when you go from the big ring to the small ring. It pauses for a second at the first stop position and then you can release the lever to take that trim away if you need to. The idea is to keep you from dropping the chain just as the Di2 shifter does," says Lawrence.
In appearance, the front shifter has a distinctive, long vertical arm that necessitates a new setup procedure. It involves a tool that's included with the groupset to help you determine the best position to run the cable through the clamping bolt. It looks intimidating, but proved an intuitive process.
The rear derailleur has been redesigned to pull more cable per shift, a design Shimano has used on mountain bike groupsets. "It helps make the system more stable," says Lawrence, meaning shifting will be more forgiving of variations in cable tension that might occur over time and will be less likely to negatively impact shifting performance.
Altered pivot point placement and polymer-coated cables increase braking sensitivity and power.
The new brake design changes the location of the dual pivots to provide greater braking power and smoother modulation. As is the case with the shifters, the polymer coated cable for the brakes necessitates a new clamp design relative to older groups to hold the slippery cables.
The Dura-Ace mechanical brifters now have the ergonomics of Dura-Ace Di2 brifters.
More Pronounced Clicks
Based on feedback that the DA 7900 mechanical group's shifting felt too light, Shimano designed shifting on the 9000 to have more clearly defined, positive clicks and tactile feedback to indicate a successfully executed shift. When you shift with 9000, then, lever feel starts with greater resistance so you know you've made the shift, then becomes lighter later in the blade stroke. Lawrence says this design also better suits the way our hands work--you naturally have greater hand leverage and strength in the beginning phase of the stroke and less later in the lever movement.
Coupled with a hollow outer chainring, the 4-arm crank design increases stiffness while losing weight and enables use of a broad range of chainring sizes without having to swap to a compact crankset.
New Spider and Chainrings
The 77 grams Dura-Ace 9000 loses versus the last generation of Dura-Ace comes from the new four-arm spider, hollow outer chainring and redesigned bottom bracket. The four-arm spider serves as 9000's most noticeable visual differentiator. This new design allows for use of both 'standard' and 'compact' chainrings without having to change crank arms to accommodate different bolt circle diameters. That makes it simple and easy to set up one crankset for every type of road riding, from extreme climbing to time trialing, without having to change cranksets or bikes. Available chainring combinations include 50-34T/52-36T/52-38T/53-39T/54-42T/55-42T.
11-speed opens up new possibilities for both tighter and broader gearing.
Shifting Possibilites
The eleven speed cassette opens up new possibilities for tight shifting over broad gear ranges and also allows for novel combinations like an 11-28 cassette that is basically what was formerly an 11-25 with a 28. Available configurations include 11-23T/11-25T/11-28T/12-25T/12-28T. "I'm sure the 11-28 will become the most popular cassette," says Lawrence, who chooses it for his personal road rigs. "It allows me to race the same cassette in a flat crit that I would use for a hilly road race without having to switch gearing."
Shimano pumps out a full range of wheels to accommodate every road riding style.
Wheels: Innovations & Options
The Dura-Ace wheel line encompasses a broad range of hoops to accommodate every training or racing need. Model names correspond to rim depth--C24=24 mm rim depth. Available options include the tubeless-ready C24-TL, the standard aluminum/carbon clincher C24-CL, the C35-CL aluminum/carbon clincher, the aluminum/carbon C50-CL, and four all-carbon tubulars: the C24-TU, C35-TU, C50-TU and the new C75-TU.
On the Road
Below find a complete price breakdown for DA 9000 and a weight comparison of DA 9000 versus DA 7900. Watch for a complete road-tested review of the group in coming months.
Complete Price Breakdown - DA9000
Weight Comparison Dura-Ace 7900 vs Dura-Ace 9000
Dura-Ace 7900
Other Weights
9000 Cassettes
Improved Ergonomics
Font Derailleur
On the Road
- Shifters - $629
- Front derailleur - $129
- Rear derailleur (short cage) - $249
- Crankset - $679
- Bottom Bracket - $49
- Brakes - $399
- Cassette (11-28) - $299
- Chain - $59
- Wheels - (see spreadsheet)
- Pedals - $399
- Complete Group - $2494.92 (not including wheels and pedals)
Dura-Ace 7900
- Rear Derailleur: 166 grams
- Front Derailleur: 67
- Shift Levers: 379
- Brakes: 293
- Crankset/Bottom Bracket: 735 (170mm cranks, 53-39 chainring)
- Cassette: 163 (11-23)
- Chain: 252 (114 links)
- Total: 2055 grams
- Rear Derailleur: 158 (-8)
- Front Derailleur: 66 (-1)
- Shift Levers: 365 (-14)
- Brakes: 297 (+4)
- Crankset/Bottom Bracket: 683 (-52 from the new 4-arm spider design)
- Cassette: 166 (+3--from adding 11th speed)
- Chain: 243 (-9)
- Total: 1978 grams (-77)
Other Weights
9000 Cassettes
- 11-23 = 165 grams
- 11-25 = 175
- 12-25 = 189
- 11-28 = 193
- 12-28 = 205
- Front Hub = 120
- Rear Hub = 247
