Endura Pro SL Lite collection revealed
Pro SL Lite Bibshort available in three pad width options
Apparel News Uncategorized
Endura Pro SL Lite Collection
Garment technologies developed by Endura for the most demanding riders in professional cycling, including the Movistar team, are now available to cyclists who ride only for passion, thanks to their flagship collection for warm weather riding – Pro SL Lite.
New this year, the Pro SL Lite Bibshort is built around a new pad that uses reticulated foam with a more open cell structure to enhance moisture transfer. It is offered in three pad width options. Perforated side panels and a lighter, simpler construction complete the picture of a bibshort made for warm weather riding – and a perfect companion to the Pro SL Lite Jersey.
Movistar Team’s hot weather favorite, the Pro SL Lite Bibshort, is based on the Pro SL Bibshort with multi pad width precision fit. Made from Italian Power Lycra fabric with Coldblack technology which dramatically reduces heat build-up, the Pro SL Lite features strategically positioned perforated Lycra panels for improved breathability.
The bibshort’s ergonomic, pre-shaped multi-panel construction provides a perfect fit. Also developed to cope with hot climates is the all new 700 Series Lite Pad. It incorporates innovative “reticulated” foam which has a more open cell structure than conventional foams, allowing for increased air flow and faster moisture transfer through the pad, making it ideally suited to hot weather use.
To ensure best comfort and performance with padding exactly where you need it and no excess fabric, the Pro SL Lite Bibshort is available in 3 pad width options. The Endura pad fitting tool helps you to select the correct one for your pelvic geometry and riding style. Learn more at www.endurasport.com. High-end details include the laser cut rear pocket and raw edge hem with inner silicone print.
Updated for Spring/Summer 2018, the Pro SL Lite Jersey II is available in a subtle black version and in a distinguished mulberry color. This super light race jersey comes in an athletic, non-flap race fit. It combines extra fine, light mesh front panels with rapid wicking Translite rear panels with UPF25 for effective sun protection. The Lycra sleeves are held in place with silicone internal cuff grippers, and the lightweight internal hem elastic with silicone gripper prevents the jersey from riding up. The minimalist, low weight triple rear pocket construction stows away all your summer riding essentials.
For those days that start out crisp and then turn into a scorcher, complete your outfit with the Pro SL Lite Gilet. This packable, lightweight summer gilet offers wind protection, then stows away easily into your jersey pocket when not in use.
Endura are also offering a 90-day comfort guarantee for all Pro SL products. If you are not satisfied with your Pro SL item, then they offer a no-quibble refund or replacement within 90 days of purchase.
For more details and pricing check out www.endurasport.com.
