First Look: Raleigh RXC Pro Disc adds thru-axles, improves ride
Cross Sea Otter Classic
Raleigh’s new ‘cross rig complete with thru-axles front and rear.
Add Raleigh to the growing list of cyclocross bike makers going the way of the thru-axle. Joining the likes of Giant, Felt, Focus and others, Raleigh has revamped its full carbon RXC Pro Disc model with a 142x12mm-100x15mm thru-axle set-up it claims improves both handling and braking performance.
Raleigh RXC Pro Disc Raleigh RXC Pro Disc
Improved mud clearance and a 27.2mm seat post should conspire to improve overall ride experience.
Change did not stop their. The new rig, which will be raced by the U.S.-based Raleigh-Clement racing team and be available starting in July, also boasts a host of frame modifications: reshaped chainstays that avail 7mm more heel clearance to counteract the wider axle spacing; a reshaped BB bridge that provides more tire (and mud) clearance; thinner top tube and seat stays claimed to improve ride quality; and a lower BB height, which should improve handling but will reduce pedal clearance.
Raleigh is now making its own carbon forks. The rear end beefed up thanks to a 142x12mm thru-axle.
Raleigh also made the switch to a 27.2mm seat post for more vertical compliance, and scrapped last model year’s ENVE carbon fork in favor of one built in house and designed to work with the bike’s new thru-axle set-up. Additional enhancements include smoother cable routing, which should reduce drag when shifting front and rear derailleurs.
Clement tires wrapped around American Classic tubeless-ready wheels complete the new package.
Exact pricing is not set yet, but Raleigh says to expect the top end model to come in around $5,000 and be spec’d with tubeless ready American Classic wheels and a Shimano Ultegra Di2 electronic shifting and Shimano R785 hydraulic disc brakes. One step down will be a Shimano 105 model with the same frame and fork, and an MSRP around $3,000.
More info at www.raleighusa.com
Do you own a Raleigh RXC? Help us become a better resource and write a review!
  • Mykel says:
    Sweet. The geometry seems quite similar to my 09′ Raleigh Gran Prix. I love! My Raleigh! I use it for a an incredibly zippy touring/commuter. I’ll be checking to see if I can get the new RXC without the components. Campy only on my rides!
  • Michael says:
    Jason,
    I want to use bike on gravel. Your thoughts? Any idea how large a tire will fit?
    Thank you
