Signs that someone in your life has made the transformation from occasional bike rider to full fledged cyclist? They wonder out loud if it's okay for men to shave their legs. They start talking about watts, lactate threshold, and recovery rides. And they tell you with a straight face that carbon fiber is arguably the world's greatest gift to man. If any of this sounds familiar, then that special someone has likely already purchased the bicycling basics: a bike, helmet, shoes, jersey and shorts. Help them fill out their gear needs with one of these great gifts.
Eurostyle Chamois Butt'r Chamois Cream
Don't let your significant other learn this lesson the hard way. When heading out on a long ride, a little lubrication on the chain - and their nether region - is always a good idea. A good chamois cream such as Paceline's Eurostyle Chamois Butt'r helps prevent uncomfortable rubbing and chafing on the bike and easily washes out of clothing when riding is done. The Eurostyle formulation has anti-bacterial properties and a touch of menthol for subtle cooling.
MSRP: $20
More Info: www.PacelineProducts.com
Shimano Ultegra Pedals
Your newbie cyclist may not be ready to make the jump to clipless pedals right away, but when they are you can't go wrong with Shimano pedals. The new Ultegra 6800s include high-zoot features such as weight-reducing carbon body construction and increased rigidity for efficient power transfer. But it's the wide, stable platform and ease of engagement that will most benefit someone new to the sport. Combine that with a simple-to-use tension release adjuster, and this is a pedal that will work just as well for cycling rookies as for seasoned veterans.
MSRP: $200
More Info: www.shimano.com
Sugoi RSE Neoshell Jacket
At some point every cyclist gets caught in the rain, so you might as well be prepared. The Sugoi RSE Neoshell Jacket does a solid job of keeping moisture out, while also letting heat and perspiration escape. The main body utilizes Polartec Neoshell material, which has the breathability and stretch that's more reminiscent of a soft shell, but the wet-weather protection of a heartier storm shell. Reflective accents increase low light visibility, rear zippered pockets provide safe storage for a phone, snack and cash, and an offset front zipper improves fit and comfort around the neck.
MSRP: $280
More Info: www.sugoi.com
WD-40 Wash, Polish and Lube
Any seasoned bike mechanic will tell you, a clean bike is a happy bike. When a bike is clean it runs better. It's also easier to spot trouble issues such as a crack in the frame. The best method is soap, a sponge, and a hose at low pressure. That will get dirt and grit off but wont hurt any of the parts. So what to use? We're fans of the new WD-40 line of bike specific products that includes a foaming wash, heavy duty degreaser, frame protecting polish, and wet and dry lube, which collectively cover all the key bases of basic bike maintenance.
MSRP: $52 for Full Kit
More Info: www.wd40bike.com
Zinn & the Art of Road Bike Maintenance
Phase 2 of basic bike maintenance requires learning to do basic repairs (and eventually a few more complex ones). Zinn & the Art of Road Bike Maintenance is the gold standard textbook for aspiring home mechanics. From simple tasks such as fixing a flat tire to advanced overhauls of drivetrains or brakes, this book's step-by-step guides explain the tasks and tools your newbie will need to get the job done right.
MSRP: $25
More Info: VeloPress.com
Leg Hair Trimmer
We're not necessarily advocating that your newbie cyclist should start shaving his legs. But if they really want to look the part of a true roadie, then foregoing leg hair is a rite of passage. Once that threshold is crossed, it's all about using the right tool. And a standard face razor is not that tool - at least not the first time. Instead, get them a hair trimmer like this model from Wahl. This drastically cuts down on time required to complete that first major mow, and drastically reduces the chance that they'll slice open their femoral artery in the process.
MSRP: For Men, $40
More Info: www.target.com
2013 RoadBikeReview Holiday Gift Guides:
Cold Weather Warrior »
Cyclocross Fanatic »
Digital Cameras For Cyclists »
For The Cyclist Who Has (Almost) Everything »
Gear For The Endurance Junkie »
Gear For the Gravel Grinder »
Great Gear For Under $50 »
Presents for the Urban Jungle »
Repurposed Gifts for the Green Cyclist »
The Newbie Road Rider »
Type A Crit Racer »
When Money Is No Object »
2013 Mtbr Holiday Gift Guides:
For The Beginner Mountain Biker »
For The Tech Geek Rider »
Gifts for that Special Angry Singlespeeder in Your Life »
Mtbr's All-Mountain Brown Friday »
POV Video Cameras and Electronics »
Stocking Stuffers for Mountain »
