Interbike 2015: New K-Edge chain guide, plus computer and camera mounts
Precision CNC machined parts designed to securely hold gadgets in place
Gear Interbike
Interbike RoadBikeReview
These new computer mounts for Garmin (MSRP $35-$65) are designed for the Edge, Forerunner, and Touring cycling computers.
These new computer mounts for Garmin (MSRP $35-$65) are designed for the Edge, Forerunner, and Touring cycling computers (click to enlarge).
Idaho’s K-Edge has added to its expanding portfolio of precision machined chain catchers, camera mounts, and computer mounts for bicycles. New products launched at Interbike include the K-Edge Single Ring CX chain guide, new computer mounts for Garmin units, and the GO BIG camera mount for GoPro.
The CNC machined aluminum mount includes an injection molded co-polymer insert to lock the Garmin in place at four secure locking points.
The CNC machined aluminum mount includes an injection molded co-polymer insert to lock the Garmin in place at four secure locking points (click to enlarge).
K-Edge Computer Mount
These new computer mounts for Garmin (MSRP $35-$65) are designed for the Edge, Forerunner, and Touring cycling computers. This next generation mount is stronger, easier to use, and more versatile than previous iterations. They are also available as a combo mount that includes the GoPro interface for camera or light attachment.
The CNC machined aluminum mount includes an injection molded co-polymer insert to lock the Garmin in place at four secure locking points with ¼ turn strength and security. In the event of a crash, the insert is designed to break before the tabs on the back of the Garmin fail. The mount is also designed to keep the Garmin low, tight and aero on the handlebars. It features a new hinged handlebar clamp for ease of installation and removal, as well as both 31.8mm and 35.0mm diameter handlebar capability.
The new mount is CNC machined from billet aluminum and engineered to hold the camera in place better than plastic mounts.
The new mount is CNC machined from billet aluminum and engineered to hold the camera in place better than plastic mounts (click to enlarge).
K-Edge GO BIG Camera Mount
These new camera mounts (MSRP $45-$555) work with GoPro, Shimano, Garmin, and any camera or light that supports the GoPro interface. The GO BIG mount is CNC machined from billet aluminum and engineered to hold the camera in place better than plastic mounts, regardless of terrain. The GO BIG mount comes in three versions for optimum placement on the handlebar. All three versions feature a new hinged handlebar clamp for ease of installation and removal, as well as both 31.8mm and 35.0mm diameter handlebar capability.
The new guide is engineered to be used in combination with SRAM CX1 and other 1x systems.
The new guide is engineered to be used in combination with SRAM CX1 and other 1x systems (click to enlarge).
K-Edge Single Ring CX Chain Guide
This new $130 guide is crafted for single ring setups and is engineered to be used in combination with SRAM CX1 and other 1x systems. The Single Ring CX guide is built with a lightweight and durable aluminum cage to minimize lateral movement of the chain which prevents chain derailment.
For more information visit www.acecosportgroup.com.
This article is part of RoadBikeReview’s coverage of the 2015 Interbike trade show in Las Vegas. For more from Interbike CLICK HERE.
