Interbike 2016: Weird, wacky, and wonderful
There's no such thing as a bad idea... most of the time
Interbike
Interbike RoadBikeReview
No this is not a map of New York City, not a usable one anyway.
Under normal light conditions, this commuter’centric jacket offers all the features you’d expect from Showers Pass. It’s waterproof with fully taped seams and robust YKK zippers. The hood fits over your helmet, core vents prevent overheating, and the softshell fabric is durable and moisture wicking. But hit it with a splash of light and its true feature is illuminated. Utilizing a special MapREflect fabric, it makes its wearer highly visible at night. And because of the unique map pattern, no two jackets are exactly alike. — Jason Sumner
American chopper-inspired e-scooter.
If you make a wrong turn off the main drag, you’ll end up in the Bermuda Triangle of e-things. While there are some gems, most of the products on display are sketchy electric powered contraptions. — Saris Mercanti
Lazer attempts to limit compromise with its new wind cheating lid.
Choosing new cycling gear is often an act of compromise. There’s a reason you hear people say, “strong, light, cheap, pick two.” When it comes to road helmets that choice typically boils down to aerodynamics versus ventilation. Lazer is doing its best to deliver both with the stealthy (albeit a little odd looking) Bullet aero road helmet. It has a narrow shape and closed shell design to efficiently cut through the wind, but also an retractable ventilation panel that you can open up for long climbs when things begin to heat up. There are also small side vents and a large rear exhaust port to help keep you cool. — JS
Folding fat e-bike.
Folding fat e-bike.
A fat tire folding e-bike? This is essentially a rolling parody of the current cycling market. — SM
It’s best to look good — and be dry — when riding your bike.
Here’s another oddity from Eurobike, this time courtesy of POC. There wasn’t a hole lot of info to go along with this display, but near as we can tell, the well-known Swedish helmet, protection, and apparel maker has its eye on the fashion world with this line of rain jackets that will let you get to work dry and in style. — JS
It’s not what it looks like, we think.
E-bikes are not motorcycles, promise. — Saris Mercanti
If you’re not a fan of the full-on Storm Trooper look, but still want to add a little extra protection to your ride, this base layer is a great option.
All by itself, the humble base layer serves a critical on-the-bike role, wicking moisture away from your skin, which depending on the weather, can help keep you cool or from getting chilled. But Dainese has taken this protective theme a step further with its TrailKnit Pro Armor Tee, adding a pair of Pro Armor shoulder pads and multi-layer crash absorb back protector. The beauty of the system is that both can be removed when not needed, leaving you with a function piece of technical clothing. Crit racing anyone? — JS
Phil Wood V10 fat bike.
Another electric motorcycle disguised as a bike. — SM
What’s next, turbo chargers and NOS tanks?
This is actually a leftover from our time at the Eurobike trade show in Germany. The nuts and bolts is that BrakeForceOne is an anti-lock brake system for e-bikes that’s being designed by a small automotive supplier based near Stuttgart. The ABS system is designed to aid inexperienced riders piloting heavier and faster e-bikes, especially on wet or rough surfaces. Small actuators are incorporated into the bike’s electronics and can be installed anywhere between the brake lever and caliper. The aim is to reduce the pressure within the hydraulic tubing so that the brakes can be activated with less force. Sensors then detect whether a wheel has locked up, which causes the actuator to regulate pressure, assuring controlled deceleration. The system is set to hit the market sometime in 2017. — JS
Botox.
Botox.
For whatever reason, a not-Botox-Botox booth was also nestled in this random corner. — SM
Anything that can help with search and rescue missions seems like a sound idea to us.
POC has long had a rep for pushing the envelop of safety innovation, and this lid is no exception. The enduro-racing-ready Tectal has a reinforced EPS liner and uni-body shell for better impact absorption. But more significantly it includes a RECCO reflector that can help searchers find you if you get lost in the woods. The device works similar to an avalanche beacon, where a signal is sent out and then bounces off the reflector and back to the sender providing location information. — JS
Can you even barspin, bro?
In addition to strange electric contraptions, there were a number of awesome pit bikes. No one needs a micro BMX bike with ape bars, but they look fun as hell. — SM
Continue to page 2 for weird, wacky, and wonderful from Interbike »
