Lemond Revolution Indoor Bike Trainer Review
- Price is $499. $549 with cogset
- Weight: 32 lbs
- direct drive eliminates the wheel and tire interface from the trainer
- Resistance is fan based.
Inspired by the original wind resistance trainer that Greg LeMond used to prepare with, LeMond Fitness introduced the all-new Revolution bike trainer earlier this year. It promises to deliver the inustry's most real-to life road feel and performance output to ensure cyclists of all levels stay in peak physical condition regardless of the weather outside.
Featuring what Lemond coins as HIT, High Inertia Technology, it's designed with a large, weighted flywheel that emulates the inertia of a rolling bicycle. It spins freely when the pedals aren't engaged and delivers progressive wind resistance to simulate real-world conditions. The design is said to create a smooth, natural feel while pedaling with no lag when the rider slows down or changes gears, lets see if their claims are true...
What we have here is a fresh approach at a bike trainer. It eliminates the rear wheel and the bike attaches directly to this trainer. So you need a compatible cog installed on the trainer to get proper shifting. Shimano, Campy, SRAM, 9-10-11 speed... make sure you get the right one. So switching different bikes onto this trainer is not as practical as most other trainers. Also, you would be really blessed (as we are) if your wheel cassette position is identical to the trainer's. In this case, there will be zero derailleur adjustment required when mounting to the trainer.
When all is set up, the rider is rewarded by a very realistic pedaling experience. It's just like pedaling outdoors in wide open smooth tarmac. If that is really, really important to you and you're tired of wearing out tires on the trainer then you may have found the right product for you.
Of course, there are compromises so read on. If you're looking for a quiet trainer that you can set up in the living room with any of your bikes and you want it portable and under $300, this may not be a good option.
[youtube width="640" height="385"]httpv://www.youtube.com/watch?v=5VeMNv2FxJE
Strengths:
- interface between bike and trainer is locked and solid.
- does not wear out the tire
- pedaling action with coasting is very realistic because of the massive flywheel positioned at the edge of the fan blades
- extremely sturdy and stable under heavy pedaling and out of the saddle efforts
- bike is level and does not need a trainer block to prop up the front is not required
- wind resistance is light during start up and progressively gets heavier as load increases. This is much more realistic than fluid, magnetic or friction resistance.
- performance data will be available soon with a Lemond Power Pilot for $350 with calibrated watts downloable through USB
Weaknesses:
- it can get loud at high pedaling levels. Our model is early production and they claim this will be improved significantly.
- need for small derrailleur adjustments is a possibility if your wheelset cog alignment does not match the trainer's.
- one really has to choose between using this with a 9-speed or 10-speed (aka road or mountain bike). Changing cog sets is not convenient
- 29er mountain bike will be slightly raised on the front end
- Downhill axle bikes like 150mm are not compatible.
- does not fold up for easy transport. This plus the 33 lb weight means it's not that portable
- your old bike computer with rear wheel sensor will not pick up mileage because there is no rear wheel.
- mounting is slightly more difficult than rollers or trainers that lock on to the skewer.
Bottom Line:
Bottom line is this trainer pedals better than any other trainer before it. It spins up easy, it coasts well and loads up to 700 watts in a very realistic manner. The pedal to trainer interface is rock solid so there's no squeaks, creaks and disconcerting movement and flexing. So you are free to just pedal and coast, go on anaerobic intervals or go virtual Pyrenees climbing with your DVDs. This unit offers more realistic pedaling than any trainer, roller or spin bike we've tried.
Of course all is not a bed of roses. Noise, portability, compatibility with different bikes are all downsides. And it's not cheap either at $550. But we feel that it still delivers a solid value for the right buyer.
So it could be a 5-star product if you are the right buyer just looking for the best pedaling action. But the list of weaknesses is long so make sure this trainer fits your usage and requirements.
The right buyer is one that puts thousands of miles on a trainer using a dedicated trainer bike(s). Noise is not a big concern for this buyer but the uncompromised pedaling feel is. That is where the Lemond Revolution trainer delivers.
Overall
4.5 out of 5
Value
4.25 out of 5
