The folks at Mavic are a cautious bunch. Despite being the co-inventors of the original UST (universal system tubeless) for mountain biking back in the late 1990s, they're just now jumping into the road tubeless fray. Today, the French company launched a complete line of road UST wheels that includes both carbon and aluminum models of Comete, Cosmic, Ksyrium, and Allroad models.
Use of a Kevlar bead is claimed to help ease tire installation and removal because a Kevlar tire bead is more pliable than the standard carbon bead of other tubeless tires on the market.
Mavic's elevator pitch is that UST is the only standard in road tubeless that considers both the rim and tire as a system. This system approach is something they've been pushing for a while in both mountain and road applications. "It's not just a rim, a wheel, or tire considered alone, but the match between precisely manufactured tire beads (stiffness and diameter) and rim contour," reads the associated PR material.
This, Mavic claims, creates the easiest and safest road tubeless design on the market because it begins with a rim contour that follows exacting dimensions to achieve beadlock and the ability to run flat, in addition to providing consistent tire inflation."
This precise rim profile is combined with Mavic's Yksion Pro UST tire, creating a system that ensures tight control of production tolerances and a 100% match of rim and tire. It also helps ease tire installation and removal because a Kevlar tire bead is more pliable than the standard carbon bead of other tubeless tires on the market. This allows for a tool-free process that can be inflated by a standard floor pump.
Mavic also claims that overall its UST system (including sealant) is 40g lighter than a traditional tire and tube system.
And whatever tubeless system you choose, no tube means no friction with the tire resulting in faster rolling. According to Mavic, at equal pressure, removing the tube lowers rolling resistance by 15%. And with 15 PSI removed, the tubeless tire still rolls 5% faster than the tube-type set up, yet results in a more comfortable ride.
Highlights of the new Yksion Pro UST tire include use of a new rubber compound that balances grip and low rolling resistance. And as mentioned before, the Kevlar beads are more pliable than the smaller diameter and stiffer carbon beads of other road tubeless tires, allowing for a more user-friendly experience. The new tires are available in 25c and 28c widths.
Here's a complete rundown of the new wheel line-up along with pricing and expected availability.
- Comete Pro Carbon SL Disc-$1899, 1755 grams (available Q3)
- Comete Pro Carbon SL-$1799, 1635 grams (available Q3)
- Cosmic Pro Carbon SL Disc-$1899, 1570 grams (available Q3)
- Cosmic Pro Carbon SL-$1799, 1450 grams (available Q3)
- Cosmic Elite Disc-$499, 1770 grams (July availability)
- Cosmic Elite-$449, 1850 grams (July availability)
- Ksyrium Pro Carbon SL Disc- $1899, 1510 grams (available Q3)
- Ksyrium Pro Carbon SL- $1799, 1390 grams (available Q3)
- Ksyrium Pro Disc-$1099, 1620 grams (July availability)
- Ksyrium Pro-$999, 1420 grams (July availability)
- Ksyrium Elite Disc-$799, 1690 grams (July availability)
- Ksyrium Elite-$699, 1520 grams (July availability)
- Allroad Pro Disc-$1099, 1660 grams (available Q3)
- Allroad Elite Disc-$799, 1720 grams (available Q3)
- Allroad Elite RB (rim brake)-$799, 1600 grams (available Q3)
- Open Pro Disc-$99, 420 grams (available Q3)
- Open Pro-$99, 420 grams (available Q3)
- Yksion Pro UST (tire)-$69, 260 grams
For more info visit www.mavic.com.
