New road and mountain kit from Pactimo
Colorado clothing maker continues to impress with performance, value
Apparel
2017 Pactimo Collection
Pactimo has been placing emphasis on long rides, with kit that’s built to ride in from dawn to dusk.
Colorado-based cycling apparel maker Pactimo has another round of solid looking kit for the summer bike season. We’re continually impressed with the value-performance proposition that they’re able to offer. Pactimo gear is never overly fancy or pretentious. It just works well. Here’s a gallery of a few of their new and updated pieces for road and mountain.
The men’s Summit Stratos Bib Short utilizes a ceramic pattern that’s pressed into the fabric to increase abrasion resistance and also lower weight. You can literally see through it in the light, but don’t worry, it’s still fully UV protective. Price is $225. More info at www.pactimo.com
The 7.5cm compressive leg bands have soft silicone leg grippers to keep everything in place. More info at www.pactimo.com
This light and breathable bid will keep you cool and comfortable on hot days. The chamois has a two-piece anatomic shape, and features a flexible and perforated top layer that reduces weight and increases moisture transfer. The perforation also makes it more flexible, increasing comfort. Lay flat shoulder straps mean no binding on your skin. More info at www.pactimo.com
The updated Ascent 3.0 jersey uses a SwiftDry fabric that’s both soft and breathable. Four-way stretch fabric on the side panels and front maintains a comfortable aero fit, while rear pockets are designed to carry a full day’s worthy of supplies without sagging. Price is $100. More info at www.pactimo.com
Reflective trim on the rear helps keep you safer in low-light riding situations. The neck has anti-chafe tape inside the collar. More info at www.pactimo.com
Pactimo makes sure you can keep sun and sweat at bay with a full line of color matching caps. More info at www.pactimo.com
You can tie it all together with some comfortable socks. More info at www.pactimo.com
New on the mountain bike side is the Terrain Jersey, a ¾ length Henley style top made with rugged Dynamik fabric that both helps regulate body temperature — and stand up to the occasional unscheduled dismount. Price is $75 and it’s available in four eye-catching colors. More info at www.pactimo.com
Last but certainly not least are the new Pactimo Terrain Shorts, which use a four-way stretch fabric that allows for dynamic movement on the bike. Two zippered front pockets keep valuables secure, while the 14” inseam means you can wear a set of knee pads without worrying about the dreaded gaper gap. Price is $95. More info at www.pactimo.com
A double offset snap opening and internal velcro-free elastic retention system provide secure, adjustable performance. Mesh throughout the interior waist and where the top of the thigh engages the short reduce friction and increase moisture movement away from the body. More info at www.pactimo.com
