Review: Blackburn 2′Fer
A bright headlight and tail light in a 20 gram package
Lights Lights Shootout
2016 Lights Shootout
The 2Fer can be used with the built-in clip mount or with a rubber strap mount.
The 2′Fer can be used with the built-in clip mount or with a rubber strap mount (click to enlarge).
Editor’s Note: This article is part of RoadBikeReview and Mtbr’s 2016 Bike Lights Shootout. See the RoadBikeReview Commuter Lights Index and the 2016 Mtbr Headlights Index.
The Lowdown: Blackburn 2′Fer
The Blackburn 2′Fer weighs 29 grams and we measured 65 Lumens out of it. It’s rechargeable, yet only costs $25 and the kicker is it has white LEDs and red LED lights built in. Thus, it can be used in the front and the back as a versatile ‘to be seen’ light. It’s not the brightest light, but it’s certainly the smallest and most versatile light we’ve tested to date.
The Blackburn 2′Fer is discussed in the first part of this round up video below.
Stat Box
Claimed Lumens: 60 Lumens Category: Tail Light
Measured Lumens: 65 Lumens Price: $25
Run time on high: 1:30 Hours Rating: 5 5 out of 5 stars
Mounted weight: 29 grams
Pluses
Minuses
  • Has both red and white LEDs
  • Doesn’t last that long
  • Is brighter than claimed at 65 Lumens
  • Does not have lower output levels
  • 20 grams with clip or 29 grams with strap
  • $25 price for USB light is good
  • Switch has the best placement
Full Review: Blackburn 2′Fer
This was one of the pleasant surprises of the shootout. Here is a small light with a clip that claims 60 Lumens for a 20 gram light with a $25 price. We took it to the lab and it indeed measured at 65 Lumens which is even higher than claimed.
2Fer in white mode puts out a measured 65 lumens.
The 2′Fer in white mode puts out a measured 65 Lumens (click to enlarge).
The secret weapon is that it has red LEDs positioned opposite its diagonal white LEDs. Thus, at the press of the switch the white headlight can be used as a red tail light.
2Fer in red LED tail light mode.
The 2′Fer in red LED tail light mode (click to enlarge).
Integrating Sphere Measured Lumens
This light measured 65 Lumens in an integrating sphere. Claimed Lumens by the manufacturer is 60 Lumens. Compare all Lumen Tests here »
The numbers are staggering. Two lights in one for $25? That is a good deal indeed. The brightness of 65 Lumens is legitimate ‘to be seen’ output out of this 20 gram light.
The light comes with a built in clip that can be attached to a backpack, saddlebag or article of clothing. But if one wants to attach it to the handlebars or seatpost, the clip can attach to an included strap mount. This brings the system weight to 29 grams as the rubber strap is able to wrap around any tube on the bike.
Incredibly light at 20 grams.
Are two lights better than one? Is there any utility to having both white and red LEDs on the light given that they can’t be both on at the same time? The answer is yes. What the light gains is versatility. Normal use is for one light to be a headlight and the other to be a tail light. But both can be headlights if one needs to see better. Or both can be tail lights, one on the bike and one on the helmet for example. Or the lights can be shared between bikes.
For more information visit www.blackburndesign.com.
About the author: Francis Cebedo
The founder of mtbr and roadbikereview, Francis Cebedo believes that every cyclist has a lot to teach and a lot to learn. "Our websites are communal hubs for sharing cycling experiences, trading adventure stories, and passing along product information and opinions." Francis' favorite bike is the last bike he rode, whether it's a lugged commuter, ultralight carbon road steed, singlespeed or trail bike. Indeed, Francis loves cycling in all its forms and is happiest when infecting others with that same passion. This obsessive personality has also turned him into a bit of an addict when it comes to high quality coffee and IPAs.
