Review: Element Case Rogue and Sector Deliver High End iPhone Cases to the Bike Market
Gear
Element Case delivers some trick and customizable bike cases.
Element Case Rogue Side Plate is Made CNC’d.
Editor’s Note: This article originally appeared on Mtbr.
Overview
The phone, has quickly become an indispensible tool for cycling. It serves the call of ride logging duties, camera, POV video, social, communication and emergency needs. But how does one protect it or mount it?
The Element Case Rogue addresses some of those needs as it provides a sleek and protective armor for the iPhone 5. It isolates the phone with rubber dampers without making it bulky. It provides access to the control buttons that are easy to operate and give good feedback. The phone is easier to grip and handle even with gloves or in slippery conditions.
Element Case Rogue and Mounts.
Best of all really is it looks good. The materials, fit and finish of these cases are similar to Race Face or Chris King Components. Design and machining is incredible and there’s some customization available with colors and labels.
Product Highlights:
  • For iPhone 5/5s
  • Rugged, compact design protects all sides of your iPhone
  • Chassis constructed of shock absorbing TPU and polycarbonate polymers
  • Additional rear protection provided by aerospace grade carbon fiber
  • Extreme side protection provided by CNC machined T6061 aluminum
  • Belt clip/viewing stand included
  • Designed in California by active designers and engineers
  • MSRP: $99.95
Element Case Rogue Back.
Useability
Installing the case on the iPhone reveals the quality and design of this component. All the machining of the aluminum and the molding of the plastics is absolutely dialed. It is really quite a revelation to see how well protected the phone is in this compact package.
Element Case Rogue Components.
Another great revelation is that the phone becomes much easier to grip and handle when in the case. The case has contours and textures that fit the hand really well, so pulling the phone out of your pocket to take a photo doesn’t need to be delicate and precise exercise. The buttons too are awesome, as they are big and they deliver a very good tactile feel when pressed.
Downsides
Of course, there are downsides as the case is $100 in base configuration. It just goes up from there as you add customization or add mounts which are typically $30 each. This is not the end of the world if it’s a long term investment. But as phones change, this case will become obsolete just like all other phone cases. The mounts however are modular so they will work with the next generation of phone cases.
And the other downside is there’s no waterproofing with this case. So keep it dry or experience the curse of moisture in your phone’s electronics.
Element Case Rogue Holder and Stand.
Mounts
Several mounts are available and they are world class. The car mount is cool, but some real thought has been given to the bike mounts. The founder, Jeff Sasaki did a bit of work in the bike industry with companies like Fox Clothing, then his own design firm with noteable protective gear clients. So a lot of thought has been given to the bike mounts. In fact, they sent us three options, a C-clamp, a bar mount and a stem mount. All worked flawlessly in our installation and test rides.
Element Case Rogue Glass Mount:
  • Surface Mount
  • Suction cup mount
  • Articulating arm support
  • Case retention strap
  • Fuse Blok mounting adapter
  • $29.95
Element Case Rogue Handlebar Mount:
  • Zip Mount
  • Adjustable secure mounting clamp
  • $27.95
Element Case Rogue Universal Quick Release Clamp:
  • Clamp Mount
  • Quick release mounting clamp
  • $29.95
Element Case Rogue Top Cap Mount:
  • Bike Mount – Top Cap
  • Bicycle headset top cap
  • $27.95
Continue reading for info on the Element Case Sector and full photo gallery.
About the author: Francis Cebedo
The founder of mtbr and roadbikereview, Francis Cebedo believes that every cyclist has a lot to teach and a lot to learn. "Our websites are communal hubs for sharing cycling experiences, trading adventure stories, and passing along product information and opinions." Francis' favorite bike is the last bike he rode, whether it's a lugged commuter, ultralight carbon road steed, singlespeed or trail bike. Indeed, Francis loves cycling in all its forms and is happiest when infecting others with that same passion. This obsessive personality has also turned him into a bit of an addict when it comes to high quality coffee and IPAs.
  • Jeff Ferry says:
    Great review, thanks Francis. Have you looked at the Casemachine cases? They are also nice looking and good protection. I wonder if they would work with the Element clip on and bar attachment to put the phone securely on the handlebars.
