ROTOR Power Meter Crankset
News Parts Power Meters
Friedrichshafen, Germany – Revolutionize your training with ROTOR Power. ROTOR’s patented POWER meter crankset will improve your training quality and experience. And at just 30g heavier than the standard 3D+ MAS crank, it’s probably the lightest power measurement option out there (556g for 175mm w/out chainrings).
The POWER brings scientific knowledge to the road by combining two proven products: ROTOR’s 3D+ crank and the respected MEP lab power measurement system by AIP. With this rich heritage, it’s clear that the ROTOR POWER isn’t just “any old power meter”.
The POWER is in fact two, super-accurate, independent power meters; one left, one right. This gives you quality data no other system can provide:
  • Individual left & right “power balance” measurement, torque efficiency, and pedal smoothness data.
  • Unsurpassed accuracy due to symmetrical crank deformation with 8 strain gauges (no need for extensive calculus or data filtering).
  • Compatible with any ANT+ device. Firmware updates will be available.
  • Easy battery replacement. No tools required.
  • Standard Micro Adjust Spider (MAS) to give finer Q-Ring position.
  • 30mm UBB axle design allows it to be installed on almost any bike – regardless of its 24 or 30mm BB system.
    The POWER delivers on all the promises of next generation power measurement devices. Availability first quarter of 2013.
  • About the author: Thien Dinh
