SKS Raceblade Long fenders review
Easy-to-install mud guards keep body and bike debris free
Parts
Using the longest brackets, total added weight was just under 500 grams.
Using the longest brackets, total added weight was just under 500 grams (click to enlarge).
Lowdown: SKS Raceblade Fenders
Colorado isn’t exactly the bike fender capital of the world. Our mostly dry climate means unless you’re a 5-day-a-week commuter, it’s pretty easy to avoid riding in the rain. But then this past April happened. For the better part of a month, it felt like we’d all moved to Belgium, just with taller mountains. The upshot of this near-constant wet weather is that I had a good excuse to spend some time testing the SKS Raceblade Long fenders installed on my Parlee Z5 SL road bike. Find out how they fared in the ever-changing Colorado climate in the full review below.
Stat Box
Weight: 498 grams (using longest brackets) Wheel size compatibility: 700c
Max tire width: 25mm Colors: Black or silver
Price: $60 Rating: 4 Flamin' Chili Peppers 4 out of 5
Pluses
Minuses
  • Easy to install
  • Unsightly brackets
  • Keeps rider and bike clean
  • Some front fender rattle
  • Easy to remove
  • Spacing can be finicky
  • Coverage extends below hub axle
  • Adds 500 grams to bike weight
  • Ample adjustability
  • Not compatible with thru-axles
  • Compatible with disc brakes
  • Spray gap near brakes
Review: SKS Raceblade Fenders
Stereotypes aside, Germans are good at designing smart, functional products. The SKS Raceblade Long road bike fenders are a perfect example. Utilizing attachments at the brake caliper and hub, these mud deflectors do a superb job of encasing your bike’s wheels, meaning less grit and grime on you and your frame.
There is a small fender gap around the brake area. But overall our bike and body stayed remarkably clean.
There is a small fender gap around the brake area. But overall our bike and body stayed remarkably clean (click to enlarge).
With the aid of a video I found on-line, install took about 40 minutes. And now that I’ve done it once, that time could easily be cut in half. First timers need to decide which length mounting bracket to use, which is driven primarily by the girth of your fork. Mine are fairly wide, so I had to opt for the longest bracket, which pushed total weight of the set-up to just a shade under 500 grams.
The fenders extend below the hubs.
The fenders extend below the hubs (click to enlarge).
That was a small price to pay for the elimination of brown stripes up my backside, not to mention all the grit and grime that had been accumulating on my frame. No longer did I feel the impulse to bust out the bike wash kit after every wet weather ride. The guards extend past the hubs, availing near total protection. Here’s a look at the basics of the install process.
One critical pointer during install that was learned the hard way is that you need to make sure to push the brackets upwards as far as possible before retightening the caliper fixing bolt. Otherwise you’ll end up with the fender rubbing on the tire. We also had to ditch one of the brake caliper’s washers to make everything fit together snugly. However, braking performance was not affected in any way.
Continue to page 2 for more of our SKS Raceblade Long fenders review »
  • Kenny says:
    Unfortunately sometimes things break but the real test is in how the company handled the issue. Did you contact them??
