Unior Multitool Euro17 review
High quality multi-tool perfect for your adventure seat bag or hydration pack
Gear
Unior MultiTool Euro 17
Unior’s MultiTool Euro 17 features real-world usability with made-to-last quality.
What is it
This made-in-Slovenia multi-tool has you covered in the event of nearly any roadside mechanical. It incorporates modern bike tools like a valve core remover, Torx wrenches, and tiny, but functional chain tool.
Pros
  • High quality tool with hardened bit tips
  • Tool bits that are actually long enough for real-world use
Cons
  • Larger and heavier than many micro-tools
RoadBikeReview’s Take
Adventure and mixed surface riding is gaining in popularity. Even many road events are peppering in dirt sections. To match the more rugged terrain, it’s a good idea to bring along a quality multi-tool. Unior’s MultiTool Euro 17 has, you guessed it, 17 tools designed to keep you rolling after a mid-ride mechanical.
For leverage on the chain tool, the valve core remover is used as a handle.
The tool list includes 2, 2.5, 3, 4, 5, 6, and 8mm Allen keys, Torx 10 and 25, 3.3, 3.45 and DT spoke wrenches, a chain tool, Presta and Schrader valve core remover, #1 Phillips and 1.0x5mm flathead screwdrivers. Cleverly, you remove the valve core remover and thread it into the chain tool body for leverage. Each bit has a chrome-plated shank and black-oxide coated tips for increased corrosion resistance, durability, and tight tolerances.
At nearly three inches long and just over two inches wide the MultiTool Euro 17 is larger than many other multi-tools, but I would argue that it also makes it more usable. Often tiny micro-tools can’t access recessed bolt heads or provide enough leverage for removing pedals. Unior’s Euro 17 doesn’t suffer from either scenario. Even if you don’t want to carry the Euro 17 at all times, it’s a great tool to have in your car or travel tool kit.
Unior shies away from dainty, ultralight designs on the Euro 17, instead emphasizing utility.
At $40 Unior’s Euro 17 sits on the more expensive end of the multi-tool spectrum, but the quality merits the price. The MultiTool Euro 17 should last for many, many years.
Rating: 5 out of 5 5 stars
Price: $40
More Info: uniorusa.com
About the author: Nick Legan
Nick Legan is happiest with some grease under his nails and a long dirt climb ahead. As a former WorldTour team mechanic, Legan plied his trade at all the Grand Tours, Spring Classics, World Championships and even the 2008 Beijing Olympics. In recent years, gravel and ultra-distance racing has a firm grip on Legan’s attention, but his love of mountain biking and long road rides hasn’t diminished. Originally a Hoosier, Legan settled in Boulder, Colorado, 14 years ago after finishing his time at Indiana University studying French and journalism. He served as the technical editor at VeloNews for two years and now contributes to Adventure Cyclist, Mtbr and RoadBikeReview. To follow along on Legan’s cycling adventures, find him on Instagram at @nlegan and be sure to check out his new book Gravel Cycling: The Complete Guide to Gravel Racing and Adventure Bikepacking.
