Vittoria Rubino Pro G+ tire review
Art’s Cyclery puts new rubber through paces and is impressed
Tires
The Rubino Pro G+ tires uphold the previous model's reputation of durability, still showing plenty of life after 700 miles.
The Rubino Pro G+ tires uphold the previous model’s reputation of durability, still showing plenty of life after 700 miles (click to enlarge).
Editor’s Note: This article is courtesy of the team at Art’s Cyclery. The original post can be found here.
Lowdown: Vittoria Rubino Pro G+ Tire
It’s always a pleasant surprise to see this level of performance and durability in a training tire, especially at this price point. That’s why if you like to get bang for your buck, then Vittoria’s Rubino Pro G+ road tire is worth a look. Find out more in this Art’s Cyclery pro review.
Pluses
Minuses
  • Excellent performance
  • Rolling resistance
  • Low cost compared to similar performers
  • Long tread life
Review: Vittoria Rubino Pro G+ Tire
Previous iterations of the Vittoria Rubino were not impressive in terms of puncture protection or cut resistance. However, the claimed performance boost of Vittoria’s new Graphene compound necessitated a clean slate for the G+ Rubino. That’ because while this tire may still have the Rubino name, the Pro G+ is completely different. Here’s a feature-by-feature ratings breakdown with a 1-out-of-10 score for each.
Vittoria's new Graphene compound necessitated a clean slate for the G+ Rubino.
Vittoria’s new Graphene compound necessitated a clean slate for the G+ Rubino (click to enlarge).
Rolling Resistance: 5
Bad news first: The only real downside to these tires is their rolling resistance. While we don’t have fancy data to back up this claim, they simply don’t feel particularly fast. With a middle-of-the-road 248 grams weight, it seems that tread pattern is mostly to blame.
Comfort: 7
When it comes to comfort, the Rubino Pro G+ does not deviate from Vittoria’s top-notch standard. The tire rolled exceptionally smoothly over dirt, cracked roads, potholes, and cattle guards. There are only one or two other tires that feel as good as the Rubino Pro G+ at this price point.
Tread Life: 8
The previous Rubino tires had a tread-life that seemed to last forever, even when suffering through numerous cuts and punctures during their lifespan. Our test pair of Rubino Pro G+ tires uphold the previous model’s reputation of durability, still showing plenty of life after 700 miles of all-road riding, including some time on a trainer and rollers.
The only real downside to these tires is their rolling resistance. While we don't have fancy data to back up this claim, they simply don’t feel particularly fast.
The only real downside to these tires is their rolling resistance. While we don’t have fancy data to back up this claim, they simply don’t feel particularly fast (click to enlarge).
Puncture Protection: 8
The new Rubino Pro G+’s puncture protection and cut resistance is far better than older versions of the same tire. We experienced no flats during testing, and can only find a couple micro-cuts across both tires. This type of durability is typically reserved for super heavy-duty tires like Gatorskins or Armadillos, while a previous pair of Schwalbe One tires were showing substantial cuts by this mileage.
Grip: 9
Though rolling resistance is on the high side, the handoff is incredible traction. We were recently lucky enough (or unlucky enough, depending on one’s outlook) to test these tires in the rain. And while not experts in rain traction (usually we don’t ride when it rains), these tires did not disappoint on the wet roads. Nothing is better than a tire that instills confidence, especially when it comes to fun, twisty roads, or those slick wet white strips that we are all wary of.
Value: 10
For the money, this is one of the best tires that we’ve ridden, especially for training. It’s a beautiful thing to find a tire that can perform well and not break the bank. The Rubino Pro G+ gets the job done very well, while leaving you with plenty of change for necessities like flat repair and nutrition.
Overall: 7.7
If you want top-tier versatility for the lowest amount of money, then you should give the new Rubino Pro G+ a chance. For around $50 it’s one of the best all around tires we’ve ridden, performing a lot like our favorite all-rounder, the Continental Grand Prix 4000 S. You’d be hard pressed to find a smoother and more reliable ride at this price point.
Available in 23c, 25c, and 28c, all with 150tpi. Learn more at www.artscyclery.com.
About the author: Arts Cyclery
This article was originally published on the Art's Cyclery Blog. Art's Cyclery is dedicated to offering free expert advice, how-to videos, and in-depth product reviews on ArtsCyclery.com to help riders make an educated decision when selecting cycling gear.
  • MidwestJohn says:
    The old Rubino Pro Slicks were my fav all-around clincher and I’ve logged well over 20k miles on ‘em over typically bad Midwest roads. Agree that tread pattern hurts speed, which is why I use the Slicks. But must disagree with this review claiming prior RP’s were ” not impressive in terms of puncture protection or cut resistance.” I found them to be among the most durable all-around clinchers. If the new Pro G+ is indeed that much of an improvement in durability they must be incredible.
  • bikerbill says:
    I agree with MidwestJohn. The Rubino tires are super durable to my previous tire brand I used. I first used them because of low cost and they had a red side wall to match my bike. I get 9,000 miles per year and change my tires and chain every 3000 miles. I am also from the midwest, a UPPER-Upper Michigan, I have been using them for 2.5 years with only 2 flats, both times industrial staples!!! On my old brand I would have lots of micro cuts in the surface of the tire, very few if any on the Rubino’s. At 1500 miles on the tires I switch Front to Back and vise versa.
  • matt levinsky says:
    Not good.. big patch with cord for no reason. ?
