Whisky Parts Co 15QR Carbon forks and Carbon Wheels for 2013
Feature Articles Parts Video Wheels
Ben from Whisky Parts Co shows us some new 2013 carbon forks and carbon wheels. The forks use a brand new QR15 axle (taken from mountain bike technology) designed and produced in a partnership with SRAM for increased stiffness to run road disc brakes.
The Whisky No.9 road and cross thru-axle disc forks feature a Whisky exclusive optimized version of RockShox popular and easy-to-use Maxle 15mm thru-axle. It has also been modified to an easy-on-the-eyes width for carbon cross and road forks. The warranty is 5 years to the original owner and will be available around November 2012 in the U.S.
From the manufacturer:
“One tight corner is all it takes to feel just how our No.9 forks deliver a stiffer, secure connection for a more responsive ride. Add to that disc brake compatibility for stop-on-a-dime power even in the mud or rain, and the peace of mind that your front end won’t squirm when you’re bombing through sketchy turns – then you’ve got the kind of power, control and confidence usually reserved for rock stars and dictators of small countries.”
Product specs and features listed below:
Whisky No.9 Cross
  • A-to-C: 395mm
  • Offset: 45mm
  • Crown Race Diameter: 39.8mm
  • Crown Diameter: 57mm
  • Stem Clamp Diameter: 28.6mm
  • Taper Length: 85mm
  • Steerer Length: 350mm
  • Max Tire Clearance: 622c x 35mm
  • Projected Weight w/Maxle: TBD
  • Projected Weight w/o Maxle: TBD – 67g
  • Fender Mounts: Crown
  • Minimum Rotor Size: 140mm
  • Maximum Rotor Size: 185mm
  • Hub Width: 100mm
  • Finish: Gloss or Matte
  • MSRP: $595
Whisky No.9 Road-43
  • A-to-C: 367mm
  • Offset: 43mm
  • Max Tire Clearance: 700c x 28mm
  • Hub Width: 100mm
  • MSRP: $650
Whisky No.9-49
  • A-to-C: 367mm
  • Offset: 43mm
  • Hub Width: 100mm
  • MSRP: $650
For more info: whiskyparts.com
About the author: Gregg Kato
Gregg Kato studied journalism and broadcasting in college while working many different jobs including deejaying, driving a forklift and building web sites (not all at the same time). Kato enjoys riding local Portolla Valley roads. Besides being an avid cyclist, he is also a motorcycle fanatic. Two wheels, one Passion.
