Interbike 2008 - RoadbikeReview
Trail Fox 01
Trail Fox 01
TF01 Shark Metallic Matt
Shift your limits: With the brand new TF01 we are re-releasing the trailfox line. We have improved on our established rear wheel suspension Advanced Pivot System, and are using high-quality aluminium alloys and hydroforming for our frame building. The bottom bracket and the upper pivot hinge are manufactured using the groundbreaking shell construction method which pays strict attention to weight-savings. The Single-Bone-Rocker suspension guarantees optimal tire clearance for the rear wheel and uncompromising rigidity. This is a bike where the frame and components work in perfect unison helping you to overcome all terrain obstacles.
This model is available either as just the frame set or as a complete bike. You have the choice to build up your dream bike for yourself or go with our carefully chosen componentry.
Frame iSC
Fork Fox Talas 100-120-140 mm
Rear Shock Fox RP2
Groupset Shimano XT
Brakes Shimano XT Disc brake
Handlebar Scor Race
Stem Scor Race
Wheelset DT Swiss X 1800
Frameset incl. Fox RP2 Headset FSA ZS-3
<< Previous Next >>
Back to the BMC booth
Co-Motion:
BH:
