Hot Deals from Jenson USA
Tires, helmets, tools, jerseys, and much more
News
This week’s Hot Deals from Jenson USA include tires, helmets, tools and much more.
Our friends at Jenson USA always have some great sales going and this week is no exception. Check out these smoking deals and get them before they are gone.
POC Fondo Gradient Light Jersey
The Fondo Gradient Light Jersey is a lightweight cycling jersey made from a highly breathable and comfortable polyester fabric, which effectively wicks moisture away from your skin. The full-length front zipper with mesh side panels and inserts under the arms allows for optimal flexibility and breathability. The soft cuffs and collar provide a comfortable and close fit. The jersey also features three rear cargo pockets and an additional mobile phone zip pocket.
Price: $39.99 (marked down from $130) save 69%
buy now
Sidi Wire Vent Carbon Road Bike Shoes
SIDI needs no introduction when it comes to serious performance and serious comfort for serious riders. The Sidi Wire Vent Carbon Road Shoes are loaded with features and are everything you’d expect in a pro-level road shoe. It starts with the lightweight Vent Carbon Sole for the kind of stiffness that transfers power right into your pedal strokes; not to mention it provides ample ventilation for those hot summer days. The sole was designed with integrated ventilation and air channels, which can also be closed to block airflow when conditions cool down in the winter months to allow for 4-season comfort. The Soft Instep Closure System provides a wide, anatomically curved, adjustable strap that can be set to perfectly fit the instep on your foot. SIDI’s Techno-3 allow you to dial in the fit along the entire length of the shoe. By using new proprietary wire materials, SIDI was able to offer an effortless, customized fit with no binding. An adjustable heel retention device reinforces the top of the heel cup, improving the fit of the Wire Carbon Vernice by ensuring the back on the shoe is secured snugly around the heel to prevent your heel from sliding around when climbing or sprinting, which causes blisters and a loss of power transfer.
Price: $349.99 (marked down from $500) save 30%
buy now
Rotor Outer Q-Ring Chainring
The Rotor Q-ring Outer Chainring 110BCD 4Bolt has been designed to fit Shimano 4-bolt compact cranks. It features a subtle, yet efficient 10% ovality where the smallest diameter is at its weakest point of the pedal stroke. The Shimano aero Q-rings offer 3 optimum chain ring positions (OCP)) that can be adjusted to take advantage of your pedal stroke’s most efficient zone. Rotor Q-Rings vary drivetrain resistance during a pedal rotation to align with your leg’s natural strength spots and weak spots to boost your overall efficiency. In doing so, Q rings wisely utilize the strongest muscle groups to increase positive work, while picking up the slack in the weaker zones to reduce the negative work, potentially increasing a competitive cyclist’s performance by as much as 4 seconds per km in an all-out sprint. That may sound miniscule, however it’s twice the benefit of an aero wheelset, and in a sport where a second can be the difference between the top step of the podium and no podium at all; these proportions are substantial.
Price: $129.99 (marked down from $175) save 26%
buy now
Shimano PRO Torque Wrench
With so much carbon on modern bicycles, torque wrenches are becoming more of a necessity. The PRO Torque Wrench will provide you everything you need to properly tight the bolts on your stem, handlebars, seatpost and more! No longer worry if you’re over-tightening your bolts and crushing your expensive carbon fiber components with the PRO Torque Wrench.
Price: $87.99 (marked down from $139.99) save 37%
buy now
GU Energy Roctane Electrolyte Capsules
Hydration is one of the most important things while you’re riding your bike. You won’t make it far if you’re dehydrated and a ride can come to an abrupt end. The GU Energy Roctane Electrolyte Capsules is designed to supplement additional electrolyte replacement needs. They provide added electrolyte support on top of GU’s hydration-drink products. Each capsule contains electrolytes like sodium, magnesium, and chloride to aid in hydration by maintaining water balance and plasma volume. Vitamin D is important for calcium absorption and bone health. Vitamin B6 and ginger root may help to combat nausea. Take GU Roctane Electrolyte Capsules before, during, or after exercise to replenish electrolyte levels from any energy-demanding activity resulting in sweat loss.
Price: $8 (marked down from $9) save 11%
buy now
Bell Falcon MIPS Helmet
The Bell Falcon MIPS helmet represents the same attention to fit and finish that goes into every Bell helmet. With the integrated MIPS technology, the helmet can reduce rotational motion by absorbing and redirecting rotational energies and forces transferred to the head from angled impacts. The Float Fit offers precise fit dialing and the No-Twist Tri-Glides allows you to quickly adjust the fasteners to help keep straps flat and properly positioned. The added sweat guide pad pulls moisture away from your brow and away from eyewear.
Price: $74.95 (marked down from $100) save 25%
buy now
Terevail Galena 700x32c Tires
They are like a trusted wingman for those days the route consist of fast, hardpacked gravel. There are ribbons of dirt, marking the landscape for as far as the eye can see and you have the intention to explore every last bit of it at top speed. The Teravail Galena 700c tires have an intentional tread pattern to deliver low rolling resistance, reliable traction and a reinforced casing to ward off the feared punctures. This tire will beg your bike for more power. Give it what it asks for and punch it towards the horizon.
Price: $35.99 (marked down from $65) save 45%
buy now
Giro Xena Mountain Bike Gloves
The Xena Women’s Gloves are Giro’s all-mountain glove that provide the perfect amount of comfort and lightweight feel. The palm is crafted with three panels to ensure a premium fit and the Vented Clarino enhances durability. While tailored to fit women, the gloves are equpped with Touchscreen Technology that ensures usability of your touchscreen devices without the inconvenience of removing your gloves. The Xena gloves are perfect for those adventurous days out on the trails offering a women-specific fit and lightness.
Price: $8.99 (marked down from $35) save 74%
buy now
Fox Flux Matte Black Helmet
The Fox Flux Matte Black Helmet 2017 is a versatile trail helmet designed to keep you cool and comfortable throughout your ride while still providing all the protection you’d need to keep your noggin safe. The deep rear EPS profile provides plenty of rear coverage, ensuring that you’re covered for every challenge of all-mountain riding. Fox’s Detox retention system helps you dial in the perfect fit, because nothing spoils a good ride like an ill-fitting piece of gear. The included visor is removable, so you can leave it on when the sun is shining, or take it off if visors just aren’t your thing.
Price: $49.99 (marked down from $99.95) save 50%
buy now
Hope F20 Platform Pedals
The Hope F20 is a fully CNC machined platform pedals made from 2014 T6 Aluminum alloy. Perfect for scenarios when you’d rather not clip in, the F20 features 20 replaceable pins per pedal that provide excellent traction and grip. The rock solid platform is supported by a high strength Cr-mo, heat treated axle that delivers a sturdy, flex-free feel. On the downhill course, or the commute to work, the F20 grips where it counts and looks good too!
Price: $149.99
buy now
Foundation 287 Folding Multi-Tool
The Foundation 287 Folding Multi Tool empowers you with the ability to make vital mid-ride repairs and quick adjustments. Quickly dial in derailleurs, brakes, and cockpits with hex wrenches ranging from 2-8mm, a flathead and Phillips screwdriver, and a T25 Torx wrench. Come up short on a jump and need to retention your spokes? Luckily, the 287 Folding Multi Tool features a 14g /15g spoke wrench for Shimano and a spoke wrench for Mavic. No more worrying about snapping plastic tire levers in half, as two durable tire levers make fixing flats quick and effortless. The Foundation 287 Folding Multi Tool has everything you need to get you on the road or smashing trails again with little time wasted.
Price: $14.99 (marked down from $24.99) save 40%
buy now
Bell Full 9 Helmet
No other helmet manufacturer has deeper roots in motocross. Much of what Bell engineers learned from creating the award-winning Moto-9 helmet went into the Full-9 full-face mountain bike helmet. Take that unrivaled experience, combine it with feedback from downhill and BMX pros, and you have the winning formula. The Full-9 meets the most stringent ASTM Downhill Mountain Bike Racing standard as well as CPSC and CE bicycle safety benchmarks. Additional motocross trickle-down technologies include the Eject Helmet Removal System and magnetic cheekpads. Beyond that, the Full-9 includes features like Soundtrax built-in speaker pockets and audio cable routing, and an integrated breakaway camera mount. Add in a lightweight carbon shell, a wide field of view, Overbrow Ventilation intakes and Velocity Flow Ventilation and you have the world’s most advanced helmet for DH or BMX.
Price: $279.95 (marked down from $400) save 30%
buy now
Chromag Overture Semeuk-Liaison Saddle
Bespoken to meet the needs of the slope-style, dirt-jump junkie, the Overture was engineered to compliment trick variations through its grip-able and pinch-able, yet slim and highly-mobile shape. As Brandon Semenuk’s signature design, the Overture features a silicone printed pinch area with slight flares at the tail to compliment leg-pinching and no-handed moves. The 8mm Chromo rails provide a sturdy, hard-wearing connection for going big instead of going home.
Price: $55.80 (marked down from $62) save 10%
buy now
Vittoria Barzo 27.5 Tire
The Barzo 27.5″ tire is your ultimate speedster XC tire that’s fast rolling and corners with confidence. The tread pattern has a small-block layout that has an effective-edge center and lean dependent sipe angles. The Counter V-formation channels clear mud and debris build-up in a hurry, keeping grip tactile. This model of the Barzo features Vittoria’s folding specific casing and Kevlar bead, making it both lighter and faster while also reducing pinch flats and other abrasions that the trail may inflict. This is achieved through a careful choice of proprietary polyamide threads for the casing material, and a well-planned layout consisting of intentional tread angles and layers coupling.
Price: $22.95 (marked down from $49.99) save 54%
buy now
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
