Hot Deals from Jenson USA
Tires, helmets, tools, and much more
News
This week’s Hot Deals from Jenson USA include tires, helmets, tools and much more.
Our friends at Jenson USA always have some great sales going and this week is no exception. Check out these smoking deals and get them before they are gone.
Continental Gator Hardshell Wire Bead Tire
The Gator hardshell tire is for the high- mileage rider. The Durakin sidewall protection in addition to the hard shell protection, offers an extremely durable, high performing tire suited to athletic urban riding styles.
Price: $48 (marked down from $65) save 26%
buy now
Mavic Ksyrium Pro Carbon SL Disc Tubular Wheelset
Mavic’s new Ksyrium Pro Carbon Wheels are here to save you weight and improve your efficiency. The 17mm internal rim width increases air volume, and the Griplink/Powerlink tires reduce rolling resistance while maintaining grip. The improved ISM 4D rims reduce drag, allowing the wheels to cut through the air, and the double butted spokes save weight and improve efficiency.
Price: $899.99 (marked down from $2399.90) save 62%
buy now
Jagwire 1.2mm Cable End Crimps Bottle
If you’re doing regular maintenance on your bike, you’re bound to replace shifter cable at least a few times a year. Grab a bottle of Cable End Crimps by Jagwire, and never worry about frayed cables again. Use a pair of dykes to secure these to the end of your cable, and hit the road.
Price: $30 (marked down from $37.99) save 21%
buy now
Foundation Road Presta Bike Tube
Tubes rank as one of the least exciting parts of a bike to think about, but they are pretty dang essential and deserve some consideration when deciding which ones to purchase. Foundation Road Presta Valve tubes offer a great bang for your buck and come in a variety of widths to fit your individual needs. Without a tube, you don’t roll. When the you’re rolling on goes flat, you don’t roll. If you don’t have a replacement handy, your walking, not rolling.
Price: $3.79 (marked down from $7.99) save 53%
buy now
Shimano Stainless Shift Cable
Over time, cables stretch and wear, making them less efficient and reducing shift performance. Replace diminishing derailleur cables with these Shimano stainless derailleur cables for smooth and responsive shifting.
Price: $4.49 (marked down from $7.50) save 40%
buy now
Kask Rapido Helmet
The Rapido is an entry-level helmet that is molded with the highest quality of materials, designed with unique elegance attributable to Kask. Kask’s utilized their In Moulding technology, joining the inner polystyrene cap to the outer polycarbonate one, to offer better shock absorption when you need it. The Medium and Large weight in at 220 grams and 240 grams respectively. While it’s certainly not the lightest helmet on the market, it is not the heaviest. With 24 vents, there will certainly be no overheating when wearing the Rapido. The click wheel adjustment system makes the helmet a dream to wear offering pristine comfort.
Price: $79.99 (marked down from $100) save 20%
buy now
Fizik Link Saddle Bag
So maybe your saddle doesn’t have Fizik’s fancy Integrated Clip System, therefore you’re left to the more traditional Velcro strap saddle bags. We have news for you. Thanks to Fizik’s LIN:K Saddle Bag, you now no longer need ICS to mount a high quality Fizik saddle bag. The LIN:K’s Anthracite Cordura construction is hard-wearing and handsome, and it uses a Velcro attachment strap meaning it’ll easily fit any bike. Its inner mesh pocket keeps tubes and tools organized and protected, while the water-resistant zip and semi-auto lock puller keeps things dry and secure.
Price: $21 (marked down from $30) save 30%
buy now
Vittoria Peyote TNT 29er Tire
Supreme grip and great speed maintenance are what the Peyote has to offer. The tread is low profile with ramped leading edge knobs. Every knob surface has a groove or a dimple to increase grip, Vittoria incorporated 100% siping in the Peyote tread design. Symmetrical tread design with self cleaning channels. Really fast and good for cornering.
Price: $32.95 (marked down from $58) save 43%
buy now
Foundation Brass Tubeless Valve Stems
The Foundation Brass Tubeless Valve Stems fit perfectly in a wide range of tubeless wheelsets. The dependable Presta body has a removable valve core, letting you add fluid without removing the tire. A rubber flange provides an airtight seal. The threaded 44 mm body is perfect for taller rims, letting you easily access the valve with a pump or compressor.
Price: $9.99 (marked down from $29.99) save 67%
buy now
Cane Creek DB Air Inline Rear Shock
Cane Creek’s Double Barrel rear shocks have been a hit since day one, inspiring confidence with next-level adjustability and control. Originating as a piggybacked coil shock, later iterations included a piggybacked air-sprung model and then a piggybacked air-sprung model with a Climb Switch. Cane Creek has upped the ante once again by bringing the same damping characteristics of the DB shocks to the inline shock category, making it compatible with more frames than a traditional piggybacked rear shock.
Price: $225 (marked down from $550) save 59%
buy now
Foundation Mountain Presta Bike Tube
Tubes rank as one of the least exciting parts of a bike to think about, but they are pretty dang essential and deserve some consideration when deciding which ones to purchase. Foundation Mountain Presta Bike tubes offer a great bang for your buck and come in a variety of widths to fit your individual needs. When the tube you’re rolling on goes flat, you don’t roll. If you don’t have a replacement handy, your walking, not rolling, and at this price there is no reason to not have a spare handy.
buy now
Spank Spike Race Stem
Built for All Mountain rider, and Enduro racers, the Spank Spike Race Stem blends form and function seamlessly. 2D Forged for ultimate strength, then CNC weight optimized in every way, the Spike Race Stem might be a lightweight, but its iconic hourglass sectional profile creates the torsional stiffness required by Spank’s pros. The 31.8mm barclamp zone is chamfered to reduce stress risers and increase fatigue life in handlebars. The Spank Spike Race Stem brings style and confidence to any ride.
Price: $39.99 (marked down from $75) save 47%
buy now
7IDP M5 Helmet
7Idp’s M5 helmet offers up superior open face protection for the current generation of mountain bikers. This entry level helmet can do it all. It offers plenty of coverage for the back of the head and 14 large vents to keep you cool. The one hand dial fit system and rapid adjust chin make a breeze to dial in the perfect fit.
Price: $59.99
buy now
Fox Trailer Hitch Cover
Does your vehicle lack personality? If so, then you should check out the Fox Head Trailer Hitch Cover. It is designed to withstand the elements and sun exposure and fits into all standard 2″ receivers. It does not come with a hitch pin but can be used with any hitch pins.
Price: $24.95
buy now
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
