Hot Deals from Jenson USA
Tires, jersey, handlebars, helmet, seatpost and more
News
This week’s Hot Deals from Jenson USA include tires, helmets, water bottles and more.
Our friends at Jenson USA always have some great sales going and this week is no exception. Check out these smoking deals and get them before they are gone.
Vittoria Cross XM Pro II Tire
Having a good set of tires can change the way your bike rides. Having the wrong tires for the terrain you’re on could lead to performance issues. The Vittoria Cross XM Pro II tires are designed to be used in mud and soft conditions. With a lateral tread design, it helps to create traction in mud and soft dirt, and with wide knob spacing to help shed mud from the tires, you won’t have to worry about the mud sticking. With 150 TPI, this will be a go-to tire for any racer or rider looking to have some fun in the mud.
Price: $13.99 (marked down from $42) save 67%
buy now
3T Ernova Handlebar
Most riders think handlebars are just handlebars, but they are a lot more than that. A good set of handlebars can increase your riding comfort or they can increase the aerodynamics of your bike. The Ernova Handlebars from 3T offer all-day riding comfort with their large egg-shaped top section. This provides a wider surface for your hands to rest. They feature a 31.8mm handlebar clamp and are clip-on aerobar compatible. So if you like using aerobars while you ride, then these are a perfect choice.
Price: $29.99 (marked down from $80) save 63%
buy now
Colnago C60 Frame
There are many road bikes in the world, but none are as beautiful as the C60 by Colnago. The C60 is fully handmade in Italy made from carbon fiber with star-shaped lugs and tubes. The tubing of the frame has increased volume with thinner walls. The lugs are larger and stiffer and designed with the same shape as the tubes which allows for stiffer a frame and resistance to bending. The oversized downtube increases the lateral stiffness and comfort of the bike while also lightening the frame. The C60 features a bottom bracket lug which creates a stiffer and stronger bottom bracket section while also increasing the power transfer. The C60 frame and fork utilize a flat-mount brake system and 12mm thru-axles. With internal cable routing and Campagnolo EPS and Shimano Di2 compatibility, the building potential is limitless. If you’re looking to build a custom dream bike, then look no further than the C60 Disc.
Price: $3899.99 (marked down from $6199.95) save 37%
buy now
CamelBak Podium Bottle
The Camelback Podium bottle removes the problem of having to pull open, and push shut the valve on your water bottle with its bite-like Jet Valve. Camelbak’s new valve self-seals to let you sip or even squirt your beverage of choice with no fear of leaks. The Garmin-Sharp pro cycling team likes the effectiveness of the CamelBak Podium bottle so much that they choose to use them in training and during races. Give the Podium a squeeze and you’ll see why!
Price: $5.99 (marked down from $10) save 40%
buy now
Zipp Service Course SL Seatpost
Zipp managed to shave off a few grams by revamping their Service Course SL Seatpost. Though it is lighter, the seatpost is stronger and offers a precise fit that stays within budget. The low-profile clamp allows the saddle to slide farther back on the rails allowing for each rider to have their perfect fit. The clamp design also has a downward-facing bold that ensures easy micro-adjustment of the saddle even when it is mounted. Constructed with 7075 aluminum, the Service Course SL is durable, stiff and guaranteed not to disappoint. Offered in high-polished black with silver laser-etched graphics or beyond black with anodized with black.
Price: $85.99 (marked down from $117) save 27%
buy now
Giro Savant Helmet
Boasting authentic style and performance, the Savant is an excellent road helmet for riders who are price-conscious but don’t want to sacrifice performance or safety. The Savant doesn’t cost as much as Giro’s high-end models, but it’s built around the same basic technologies that make a Giro helmet unique.
Price: $49.99 (marked down from $100) save 50%
buy now
POC AVIP Jersey
The word “essential” is very often carelessly thrown around in conversation to more or less describe preferences, resulting in a devaluing of the word. With the real strength of the word “essential” in mind, it’s safe to say the POC Essential Jersey is essential to the roadie who demands a jersey with less drag and more ventilation. The shoulders and back are constructed of a woven stretch fabric that uses a compact 3D structure to improve aerodynamic performances. The body is made of 4-way stretch fabric that offers a streamlined fit for a greater range of motion and exceptional breathability. Three rear pockets and an internal zip pocket provide plenty of storage for nutritionals and spare tubes, while the “my info” pocket is designated specifically for your identification and cell phone. Essentially‚ā¨¬¶ the POC Essential Jersey will become your favorite jersey in your wardrobe.
Price: $89.99 (marked down from $170) save 47%
buy now
Continental X-King 27.5 Tires
The X- King is a super fast grippy tire. Despite the pronounced studs, the X- King rolls smoothly and very quietly. This light tire has many applications. It can be used as either a front or rear tire in a variety of terrains. The X-King is infused with Continental’s Black Chili Compound, which offers a solid grip and is self-cleaning. The shoulder lugs provide absolute stability during high-speed corners. This version of the X-King features two forms of cutting-edge tire technology: Black Chili Compound and ProTection casing.
Price: $19.95 (marked down from $69.95) save 71%
buy now
Race Face Chester Grips
Made in the USA, the Race Face Chester grips are an important and often overlooked component. Manufactured with a soft but durable compound, the Chester grips also feature a larger inner flange and longer grip area.
Price: $2.49 (marked down from $12) save 79%
buy now
Niner RIP 9 Frame
Niner has played a big part in the wheel size innovation movement of mountain biking. To them, it’s not about a larger wheel size or more accommodating geometry, it’s about sharing an entirely unique experience on two wheels. Since they began in a humble Fort Collins, Co office, Niner has focused intently on building the rowdiest and most innovative big-wheeled bikes on the market. Their RIP 9 series prides itself on a meticulously designed Aluminum frame. In the process of designing this frame, Niner has revolutionized the way a long-travel, large-wheeled bike performs. The rear suspension is remarkably versatile, counteracting squat and bob to absorb shock without stealing from your pedal stroke. With short chainstays and a low bottom bracket, this bike is remarkably fun for a 29’er.
Price: $999.99 (marked down from $2000) save 50%
buy now
CamelBak M.U.L.E. LR15 Pack
Camelbak’s iconic and versatile MTB pack is now designed to give you the Low Rider advantage. The M.U.L.E. LR combines the storage and features of the beloved M.U.L.E. pack with a lumbar design that offers more stability during aggressive downhill rides. Instead of positioning your pack weight on your shoulders, this pack shifts your load to your hips for a lower center of gravity and more freedom of movement. The pack is built around a brand new 3-liter Crux reservoir that delivers more water per sip, with a design that’s optimized for fast and fumble-free refills.
Price: $69.99 (marked down from $150) save 53%
buy now
Race Face Turbine Dropper Post
Adjusting your seat post has never been so easy thanks to dropper seatposts. The Race Face Turbine Dropper Seatpost features 125mm of travel for all-day comfort on the bike. The seatpost functions well in all conditions, even in freezing temperatures. A mechanical lock comes into play to support the rider’s weight for added security while riding.
Price: $199.99 (marked down from $469.99) save 57%
buy now
Smith Fuel Goggles
With a combination of modern styling and superior technology, the Smith V2 goggle lets you stay focused on the trail in front of you. The ChromoPop lens is tuned to bring the most out of an environment whether a storm rolls in or you’re riding deep in the shadows of the forest. Optimal contrast for all low-light conditions. The Sweat-X F.A.T. 3-layer face foam keeps the sweat from dripping down into eyes. An ultra-wide silicone backed strap keeps the goggles securely in position.
Price: $95
buy now
Bell Drifter Helmet
The Bell Drifter MIPS helmet is a perfect all-round helmet that you can use on the road or on the trail. The Multi-directional Impact Protection System helps manage rotational energies from impacts keeping you safer if you fall. With several features like Float Fit for precision fit dialing, a removable visor, and sweat guide padding to channel sweat away from your brow and eyewear, this will be a perfect choice for every day riding.
Price: $90
buy now
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
