According to the specs from Campy, my RD hanger has the wrong set back distance.
Anyone else ever measure the set back?
I used a straight edge to make a line across both wheel axles. Used that as a reference to measure square from.
Campy says the set back from the rear wheel axle to the center on RD mounting bolt should be between 4-8 mm.
The Frame and hanger are about 15mm.
Will that affect shifting?
