1 - 4 of 4 Posts
· Two wheels=freedom!
No problem for a front wheel, wind-up isn't an issue. I built a set of wheels this spring going DT Revolutions and alloy nipples all around, 32h 3X Abrosio Nemisis tubular on Record hubs. I'm heavy (~200lbs) and can really put out the watts in short spurts and was having trouble keeping the rear in true. Rebuilt with DT Comps and brass nipples and couldn't be happier.
It depends
steel515 said:
Has anyone built wheels with 1.8 or 1.8/1.6 spokes? Will they stay true for daily riding? Windup/flex too much? (For a front wheel)
Your weight, your roads, your rims, your spoke count, and your riding style will all have an impact on whether this will work for you. I weigh 180 and exclusively ride 32 spoke, 1.8/1.6 wheels with no issues. Windup is only an issue during building, and proper greasing of the spoke threads combined with good technique prevents this being a problem. The difference in wheel flex between 2.0 and 1.8 spokes is much less than the differences due to bracing angles and spoke count.
· p != b
I have a 36-spoke 3x 1.8 straight gauge front wheel, with a semi-deep rim (Mavic CXP 12 or something like that? It's pretty old).
No problems with it, I've ridden it at 200 lbs, cx, you name it.
1 - 4 of 4 Posts
