1 - 3 of 3 Posts
Kind of a basic question, but what are the options for fitting a front wheel with a 100mm hub for a 6-bolt brake rotor on a 110mm QR fork?
I assume I'll need spacers and/or a spacer kit, but would that be two spacers for the axle and also a spacer for the rotor? And anyone know what spacer sizes would be needed? Thanks for any help.
'brifter' is f'ing stupid
I guess it depends on what hub you have but I haven't seen anything out there that would get this done. You'd have to put 5mm on each side of the hub and then move the rotor back that 5mm on the non drive side. Have fun and good luck.
1 - 3 of 3 Posts
