1 - 14 of 14 Posts
Is there any functional difference between the 10 speed 105 and ultegra cassettes? My research suggests they weigh about the same, and both use the same chain.
I'm talking about average recreational/fitness use...3000-5000 km per year, some club rides, centuries, etc.
________
HOTTYMESS
Weight is the only real difference. Except for the shifters, there isn't really any difference between 105, Ultegra, and Dura-Ace, other than weight.
tim is on fire..
adn speaks the truth. shifters have slightly noticeable difference with DA...anyone who says differently are a Shimano marketer's success story...ride what works and you can afford. I've put over 7,000 mi. on a 105 cassette...no problems..still has many left in it...
Not really
Actually, DA cassettes use a bunch of Ti cogs, which makes them 1) extremely expensive, 2) wear rapidly, and 3) slightly lighter. A VERY poor return on the bang for the buck scale. Same deal with Campy Record cassettes. If you're not racing at the professional level, these cassettes make NO sense, IMO.
Great point. In this case, more $$= less durability. Poor choice for most riders.
I happen to be a fan of the SRAM 970 cassette over either Ultegra or 105. Weight weenies shows it at about equal to Ultegra in gram count (lighter than 105), but at significantly less $$$. I've abused SRAM cassettes for years on my MTB's- and now use one on my roadie. Reliable & priced right.
When it comes to cassettes - and you’re paying - go with the more economical one. I’ve used Dura Ace, Ultegra, and 105 9sp cassettes-no difference that I could perceive.
Just upgraded to 10sp and picked up 105 and Ultegra cassettes to get specific ranges. They’d have both been 105 if I could’ve gotten what I wanted.
Des
Moderatus Puisne
I seem to recall Campy claiming that Chorus-level cassettes were plated or treated differently somehow than Centaur ones, making them last a bit longer; ditto for chainrings.
Any truth in that?
No so's you'd notice
Any truth in that?
I've used Record, Chorus, and Veloce' cassettes, and the only one that seems to wear faster is the Record, due to the Ti cogs. This is based on riding each one 9-10K miles and looking at the teeth, but it's not real scientific (no measurements taken). I replace the cassette when I replace the chain, so the best experiment would probably be to replace the chain much more often and see how long you go before you get chain skip. My general experience with metal coatings is that they may help a bit with abrasion and friction, but that they wear through fairly quickly and therefore it is the strength of the underlying material. My impression is that the primary difference between Chorus and lower level cassettes is that the Chorus uses aluminum cog carriers to save (a bit of) weight.
Roadbike Rider
Isn't Ti harder than most heat treated steels?
I thought the Ti would wear better
hello....Bertrand
I sent some email through this site and never gotten answer from you.......I was asking some questions regarding your bike purchase, is it possible for you to send me an email through this site so that we can talk privately? Hope to hear from you.
Way off
Thinking doesn't make it so. Ti is NOT a wear resistant metal. My own crude tests with a Campy Record 6/3 cassette suggests that Ti wears about 5x faster than steel.
Discussion Starter · #12 · (Edited)
reply sent
________
Justin bieber fan
Roadbike Rider
Rockwell C Hardness
Isn't wear resistance related to hardness? I looked up hardness levels on metweb. Ti alloys runs from about 25-35 on the Rockwell C hardness scale. Tool steels are much harder but so much depends on the alloy and the heat treatment with many steels much softer than Ti
Hardness, shmardness
Perhaps related to, but not a function of. You can have a very hard material that is brittle and spalls easily, and it will wear quickly. I dont know that there is some other property that you can measure that will drectly predict wear resistance. Metallurgists, feel free to chime in, but it is widely known and reported that Ti cogs (and Ti chains) wear very poorly.
1 - 14 of 14 Posts
