1 - 13 of 13 Posts
01100110012
The Surly Tule fits in most seat packs and the spoon-shaped handle works well tightening / removing the bolts. I also use the Pedros Trixie in my larger seat bag with along with a micro pump. Both also function as bottle openers, although I have only used that feature in the garage :)
Cheers Eric
I keep a Surly wrench in the seat pack so that I'll always have a viable tool but I usually try try to stuff a Campy peanut butter wrench in the jersey pocket, just in case. The latter is easier to use but the former always works in a pinch...
I formerly kept a regular length Craftsman combo wrench in my seatbag. I recently simplified to a much smaller Lezyne bag so the wrench didn't fit. The PDW 3wrencho easily fits. I flatted on Friday, felt dumb that I didn't try the PDW first to see if I had enough leverage. But good fortune was with me; standing on it worked fine.
Related story, on a group ride a few weeks ago, a new rider showed up on a Felt SS. He hit a pothole and flatted. The rest of us had geared bikes, so no wrench. It took us over an hour to repair his pinch flat without taking the wheel off.
I'd recommend several $20 bills folded up ... buy your way out of any equipment failure.
I put tubless, i.e. solid, tires on my fixie. No flats, ever.
You should see the looks when I park it and folks start realizing that it has no valves.
Yep, only spoke holes. They are solid tires, no tubes, no valves sticking out.
Really freaks some folks out.
Take 1 regular length 15mm box/ring wrench, then use a carbide hacksaw blade or cutoff wheel to slice that box end off. Leaves you with a decent size handle for torque and a tool that will fit in any saddle bag I consider to be of usable size.
Master debator.
I throw a 15mm wrench in my back jersey pocket. If I crash and get skewered I guess I'll rethink that, if there is a next time.
So I get that we all have to make our own decisions on our respective risk tolerances - but being impaled on a peanut butter wrench with no sharp edges isn't even on my radar scope. In fact, I sometimes carry a micro-pump in my jersey which might double my risk. I guess I just like to live dangerously!
1 - 13 of 13 Posts
