1 - 1 of 1 Posts
15mm to 12mm fork adapters now available in the UK. These adapters fit in your fork and reduce the diameter from 15mm to 12mm, allowing you to use any 12mm thru axle wheelset, I thought this was a great solution and I have no doubts many other cyclists in the UK have had this problem too.
This article explains the adapters in more detail: https://www.gravelcyclist.com/bicycle-tech/expand-your-wheel-options-with-jjbp-15-12-fork-conversion-kits-use-12mm-wheels-with-15mm-forks/
We have adapters for nearly every model of bike/fork dimension going. Please see our eBay shop for the range of products.
Many thanks!
Josh
1 - 1 of 1 Posts
