1 - 13 of 13 Posts
Roadbike Rider
Looking for a recommendation for custom wheels as follows
  • Weigh 160 pounds
  • FTP, not even 200 Watts
  • Frame is a Merlin Extralight
  • I already have Ultegra 32 hole, 10 speed hubs
  • I use the bike on broken pavement, urban bike paths, chip-seal and light off road
  • Also used on group rides on wet and gritty winter roads
  • Currently run 28c Conti 4 Seasons
  • Not that concerned about the price
I have a LBS with a very good builder so I just need to figure out rims and spokes.
I'm looking for a durable alloy rim but I don't need something for a Clydesdale either. I looked at Velocity, HED and the new Mavic Open pros. What would be the best option?
Thanks: Chainstay
With those hubs you can ride any rim you want. Use double butted spokes. I have h plus son archetypes and like them. My wife has pacenti sl23, and they are also nice.
Sent from my XT1565 using Tapatalk
I built a set of wheels for my wife with those hubs and used Velocity A23 rims and Sapim Laser spokes and she uses 28C Gatorskins. 1 flat in 5 years. You could use the Kinlin 31W rim and spokes of your choice. Mine would be C X-rays.
Banned Sock Puppet
Before I recommend rims, a few questions. What wheels are you using now? How wide are they? What is your frame clearance like?
If your frame clearance is tight and you go to a wider rim, your 28c tires will expand and may not fit.
Roadbike Rider
My current rims are Eastons and the outside measure is 17mm. The 28c tires fit on with a 27mm width. The chain stays are 33mm across at the tightest point. Will I be pushing it with a 27mm rim?
Banned Sock Puppet
Are you sure it's your outside rim width that's 17mm? Did you measure this yourself? It's the inside width that matters. Measure where the tire bead mounts.
Roadbike Rider
Are you sure it's your outside rim width that's 17mm? Did you measure this yourself? It's the inside width that matters. Measure where the tire bead mounts.[/QUOT
The inside measure is 14.5mm. I took all measurements with digital callipers and rechecked. They should be good. Thanks for your help.
Banned Sock Puppet
Ouch! So from the info you have provided, it sounds like you have only 3mm on each side between the tire and chain stay. If you are running 14.5mm rims, a 17mm may not fit, or at the very least, you will rub the chain stays when you flex the wheel climbing a steep hill. If you really want to go to 17mm rims, you may have to step down to a 25c tire in back.
I bolded 27mm rim as I am assuming you meant 17mm rim.
Roadbike Rider
Discussion Starter · #9 ·
Yes I meant 17mm, not 27mm rim.
I will try to borrow a wheel with a 17mm rim to try. That's the only way I'll know.
I did read to expect a change of 0.8mm on tire width when going up 2.0 mm in rim width
Banned Sock Puppet
Thanks: Chainstay
H Plus Son Archetype. Hed C2 is very good too but having used both I can't tell the difference between those and Archetypes so would say there's no point in paying more for the Heds.
CX'er
Velocity A23 is a good rim. Hed Belgium are better but more expensive. Flo 30 or one of their carbon rims might not be bad. I think you can get some boyd altamont rims from prowheelbuilder, or a few other builders now I guess, which are good.
I've had the most experience with A23's and have really enjoyed them on road bikes and CX bikes since they came out. I haven't ridden HED's rims but they're well respected. I've ridden the altamonts wheels from Boyd and they were trouble free while I had them for a season of training which included gravel miles.
Banned Sock Puppet
OP,
As you can see, there are many choices out there and many opinions to go with them. You may want to read this excellent rim review below:
Alloy Rim Roundup - Fairwheel Bikes Blog
The DT Swiss RR440 may be a good compromise for you. At 16mm internal width, this one may work for you and is a good quality rim.
1 - 13 of 13 Posts
