I assume you want the same model of crank, even if it's outdated? Otherwise, finding 175mm crankarms shouldn't be tough. If only the chainrings are worn out, then you could rebuild the crank with new rings.saddle tramp said:I'm looking to replace my wornout crankset which has 175 length crankarms. I can not find a replacememt with this length. I can find one on ebay w/172.5 crankarms.
Will I notice the 2.5mm difference? Will I have to raise my saddle up to compensate?
TX
