rydbyk said:
Yeh...I think the adrenaline may be raising my HR a bit...still, shouldn't the lactic build up still hurt equally the same as solo effort?
I am not so much asking why my HR goes up in a group...more about why it feels diff. on the body?
Holding 180 bpm solo for 7 minutes feels like my legs are going to fall off and I can barely talk.
vs.
Holding 180 bpm in a group for 7 minutes while drafting is way less agonizing.
Both are 180 bpm for 7 minutes, but they feel different on the body...
I've just looked at some of my power files to see how different (by power) two seven-minute efforts of similar HR can be. I found two spans of seven minutes with an average of 175 bpm in very different contexts.
One was the last 7 minutes of a solo climb, averaging a very steady 5.2 watts/kilo (NP almost exactly the same) for that 7 minutes, HR fluctuating over a couple of beats after having climbed to that level gradually over the 11 minutes preceding that 7 minute stretch.
The other was a 7 minute span of a crit, with heart rate fluctuating over a few more beats, but still fairly steady. Average power was a much lower 3.63 watts/kilo, but NP was 4.70 w/kg, as power fluctuated a lot more. It was a heavy-foot-on-the-gas course, coasting an off-camber corner 1/3 of the way up a short climb, then a quick blip to 13-15 watts/kilo getting back on the gas, holding 7-8 watts/kilo up the rest of the climb, easing off for several seconds on a flat, coasting a hairpin, quickly hitting 8-12 watts/kilo coming out of the turn into a descent, cruising for several seconds, easy pedaling through a turn, then getting back on it at 8-11 w/kilo out of the turn and up the first 1/3 of the short climb.
Those are fairly extreme examples, but with very similar HR numbers, I made about 40% more power on the segment of the longer solo climb than I did in the segment of the crit, and the solo climb came after about 11 minutes of only slightly easier effort (at 5.06 w/kg). Any other seven minute stretch of the crit looked about the same as the one I picked. The climbing segment was just about as uncomfortable as it could have been. The crit was not (although it had its moments). The HR is comparable. The power is not.
I know these are extreme examples, but for me, I think HR lags too much to really correlate with my perception of my discomfort, and erratic power output that includes resting moments goes a long way toward alleviating my discomfort before it necessarily drives down my HR.
