Gents - lots of good info on here. I've been commuting to work (a whopping .39 miles one way) on my mtn bike for the last year - currently running a Redline Monocog Flight w/ 700x35 kevlar belted tires. Good ride and all - but moving soon to Miami. Commute there will be longer, probably 5-10 miles - so I picked up a vintage lugged bike to transform into my single speed townie (no fixed for me). Pics of the heavy yellow beast are below - note the bent crank arms, dry rotted tires and hashed brake housings.
My goal w/ the Fuji frame is a solid, dependable, bullet-proof build that'll do 3-4 years of commuting duty before major overhauls. Nothing too fancy, but nothing cheap and expendable.
I'm handy w/ the mechanical side for the most part and will do the frame up refurb on my own (minus wheelbuilding, haven't tried that yet). I've got just a couple of questions that I was not able to answer through searches.
1) What size is the normal headset for this era bike - 1"? The headset on this bike is old, spooging some form of worn out grease and is not smooth. Based on year round riding in Miami - I imagine rain will be inevitable so I'm thinking a good Chris King 2Nut or GripNut is what I want vice a loose ball bearing Tange. King's been good for me on a couple other bikes. https://chrisking.com/headsets/hds_2nut.html
2) What's the typical life span of a White ENO freewheel? I'm 6'3", 210 - not sure if the cost/benefit of the price differential over say a Shimano freewheel is worth it on this. No doubt, their stuff is solid and I'm all in the solid/functional camp, but have no experience w/ freewheels. I run a Hope Pro2 SS hub on my Turner Sultan - that thing's gold. Little maintenance every 1k miles and it rolls like teflon. My luck w/ XT hubs was not so good. If it's like this experience, the extra $$ is worth it for the White freewheel. I just don't know what I don't know in this area.
3) Can I use a side pull caliper in-lieu of the center pull Dia-comp calipers on the bike? I'm boned up on recessed vs/ normal. There's enough material to drill out the hole to 5/8". I'll have to get longer reach calipers for 700cc wheels b/c the fronts have no adjustment left. If I go side pull, then I don't need a cable hanger and that changes the King headset top bearing cap. I'm a disc brake guy so this is new for me. Harris Cyclery kool stop pads are on the list though.
Here's my project endstate - if you see any 'weakness' w/ regards to my goal - please highlight it:
-Semi-Gloss OD green frame (think old Willys Army Jeep)
-- haven't decided whether to paint the fork OD green too or black (you can vote).
-White "stencil" font downtube graphic - "Major Pain" (play on words, not from the old Damon Wayans movie character)
-single white star on the head tube
-Black Soma 48cm Urban Pursuit bars
-Soma Urban Pursuit brake levers
-some sort of black seatpost
-Fizik saddle
-110 BCD crank, 170mm w/ Surly stainless steel chainring (bullet proof!) (I chose 110 BCD b/c I have 110 BCD on my Turner, affords some compatability w/ chainrings).
-Shimano UN54 BB
-White ENO freewheel (maybe based on #2 above)
-Salsa Delgado Cross 36H Black rims
-Black Harris Cyclery track hubs
-Fizik saddle
-Shimano UN54 BB
