Swift65 said:Sounds like you have extra money to throw away. I'm guessing your 5200 came with ultegra. Best bang for your buck. Wait until it wears out or you crash it. If your current setup is Ultegra 6600 I may let you sell it to me real cheap since it isn't good enough for your needs!!! But seriously, IMO for what your going to pay for DA and what little your going to gain in performance / weight savings it just isn't worth it.
Yes, you need an English BB. You can easily determine the seat tube diameter with a caliper (available cheap at your hardware store) or just by measuring the length of a piece of string wrapped around it, then dividing by 3.14. Generally confused about your "don’t think I need a clamp for the front derailleur?" comment. What are you trying to say/ask? Do you have a braze-on derailleur? Do you have a braze-on derailleur but are using a seat tube clamp? Please clarify.Jetski said:II think I need an English bottom bracket and I don’t think I need a clamp for the front derailleur?
There is already a bracket that is screwed into the carbon fiber down tube that my Ultegra 9 speed double front derailleur bolts onto. Will that bracket work with a new Ultegra 10 speed triple front derailleur? If so what front derailleur do I need to order, braze-on or clamp?Kerry Irons said:Yes, you need an English BB. You can easily determine the seat tube diameter with a caliper (available cheap at your hardware store) or just by measuring the length of a piece of string wrapped around it, then dividing by 3.14. Generally confused about your "don’t think I need a clamp for the front derailleur?" comment. What are you trying to say/ask? Do you have a braze-on derailleur? Do you have a braze-on derailleur but are using a seat tube clamp? Please clarify.
The bracket that is screwed onto the down tube mimics the original units that were brazed onto steel frames. You can't use a clamp type derailleur with that bracket in place. You MUST use a braze-on derailleur, and it should work fine with a double or triple derailleur.Jetski said:There is already a bracket that is screwed into the carbon fiber down tube that my Ultegra 9 speed double front derailleur bolts onto. Will that bracket work with a new Ultegra 10 speed triple front derailleur? If so what front derailleur do I need to order, braze-on or clamp?
Kerry, thanks for the help.Kerry Irons said:The bracket that is screwed onto the down tube mimics the original units that were brazed onto steel frames. You can't use a clamp type derailleur with that bracket in place. You MUST use a braze-on derailleur, and it should work fine with a double or triple derailleur.
