1 - 2 of 2 Posts
I've serviced the freewheel twice already, no problems. I went to remove the freewheel yesterday. And the axle came out on the NDS but the freewheel won't slide off. The axle on the DS spins. Hopefully I'm doing something stupid. Thats why I can't figure it out. When I have put the axle back together in the past. I use loctite blue 242. As recomended by Mavic. I'm thinking maybe I got some loctite were I shouldn't ? Any help would be appreciated. Thanx.
Procedure
Assuming you've removed the left side axle end cap, then you insert a 10 mm allen wrench into the axle on the left side and a 5 mm allen into the axle cap on the right side, unscrew that axle cap, and then the freehub body should slide off.
For techical documents and pictures:
http://www.tech-mavic.com/
User name - mavic-com
Password - dealer
1 - 2 of 2 Posts
