as for the crankset,
a move to offer outboard/oversize, as does the shimano offering.
seems a theoretical advantage more than a practical one. just seems the '07 bb juncture may squirm around. campy has presumably worked this out to be solid as can be, avoiding any problems the likes of which they had in the past with new designs such as dt ratchet shifter accuracy...
there has been no prob w/ my record carb cranks & chorus BB (i went w/ chorus in the belief all alu is stronger down there) for me, but the campy bb does demand the frame bb shell to have good chasing and facing, or else the bearings will fail readily due to the dual brgs on the drive side needing to be precisely aligned. also, the torque of the sq spindle bb must be done near to spec or could be prob.
the new '07 design may be more "forgiving" in these areas.
the oversive '07 bb scheme may result in a stiffer more durable set, but who among us is really slowed by their record sq bb set? the amount of reduced flex and bearing drag may well be undetectable by the human leg.
brakes,
seems a way to remove a *bit* 'o weight, cannot see any practical braking improvement from this.
front shifter/fd,
i noticed the front shifting on my record ultra does have a long throw, and in fact, the outer limit click position is not necessary, as it does not rub the chain in the next-to-limit position.
i have been told the long throw and outer limit postion of the pre '07 is to accommodate a triple...
also, as an aside, the trim is rarely needed, as nothing flexes enough in the area to create chain-to-fd rub, short of the extreme "cross shifting" positions.
still, the QT fd may be the most pratical real world improvement of these changes in terms of noticable advantange, or even difference, on the road.
fea said:
What do you think?
Somehow i prefer the previous/current one better
