1 - 8 of 8 Posts
If weight is a concern then get the 2009 SL2, if performance is the concern then you need to test ride it and make that judgment yourself. I love my 2009 SL Pro 52cm weighted in at just under 15lb without pedals stock.
Moderator
This isn't exactly what you are asking for but a stock 2009 Tarmac Pro SL in size 58cm, gloss white finish, SRAM Red and Ultegra pedals weighed in at 16.1 pounds at the LBS.
So. Calif.
willmarjenhoff said:
2008 Tarmac Pro 58cm weight?
Does anyone know how much the 2008 Model weights in at on a 58cm?
Do you mean frame + fork , or the entire built-up bike ?
The latter is so dependent on wheelset & gruppo choices ....
1 - 8 of 8 Posts
