1 - 2 of 2 Posts
Hi gang,
Just started building up our new team synapse and saw that the internal cable routing for the rear brake had to be done... I am not clear on how to do this... the inlet into the frame is large enough that the brake cable housing and ferrule goes all the way in, but the outlet is small enough that only the cable can come out... does that mean I should have housing that goes all the way in, then a seperate housing that goes from the outlet to the brake?
Any help would be greatly appreciated! pictures will be up next!
Thanks
1 - 2 of 2 Posts
