1 - 20 of 30 Posts
Saw this on Bike Rumor-http://www.bikerumor.com/2010/09/09/masi-drops-the-gears-with-new-2011-cxss-singlespeed-cyclocross-bike/
Anyone know any more details? Availability, rear hub spacing, etc...
Tim, got yer ears on?
Los
I have one pre ordered, I've been told by the Canadian distributor that ETA is Sept 16th, Oct delivery has been mentioned on Masi's facebook page. I don't need any more details than that, I want one. Hello SS monstercross.
Did you get a CAD price quote?
duh...
Saddle Up said:
Dirt and mud comes off with a garden hose just as easily on a white bike as it does a black one.
most of the time... I've seen red clay mud 'stain' white bikes
The Kore crank uses an external bearing BB, 42 tooth chainring, 120mm rear spacing.
A short video of all three steel Masi cyclocross bikes from Interbike 2010
Smoothy said:
120mm...is a deal breaker.
Kind of have to agree. I did race a 120mm spaced SS crosser for a few years, but going to 130mm, there are so many more offerings. At 120mm, you have pretty limited options.
Discussion Starter · #15 ·
120mm OLD? Great idea!
Fewer lightweight aftermarket hubs, weaker wheels for the off road trails that fat 45mm tires will tempt riders...
Awesome.
Los
I'm not sure I understand? The difference between a 120mm and a 130 mm SS speed hub is the amount of spacers on the axle, the hub flanges are the same distance apart. The market has a huge selection of 120 SS/FG hubs, not nearly as many at 130. What am I missing? Educate me.
Based on my personal experience, the offerings at 120mm are generally track hubs. Nothing wrong with them, but they generally aren't made for the rigors of off-road. Some of them state specifically that they should not be used off the track (something I've ignored from time to time).
You can use older hubs (6 / 7 speed) and respace them, as you mention, for 120mm. However, most modern offerings won't work that way. And with 130mm, all you need is a cog and spacer kit and you're able to run any shimano-splined rear. In addition, SS specific hubs from manufacturers like King and White Industries aren't available in 120mm.
120mm works, and as I mentioned, I ran it for many years for cross. After switching to a 130mm frame, I've noted that it's certainly much more convenient with more options available.
Discussion Starter · #19 ·
Masi, you listening?
120mm is just a bad idea. No advantages, loads of limitations.
Too bad. This was looking right up my alley.
Los
oh lonesome road for you
Is it steel? Might not be too hard to get a road wheel in there. But still, you shouldn't have to spread the drops.
1 - 20 of 30 Posts
