1 - 20 of 39 Posts
The frame near one of the rear dropouts on my beloved 2012 Roubaix seems to be rusting under the paintwork- see the bubbles in the attached photos.
As I am the original owner, would this be covered under Specialized's warranty? If so, I doubt that I would receive a new version of the frame I have, so any ideas how Specialized would address this?
Thanks in advance for the insight.
Cable Bicycle part Bicycle accessory Bicycle drivetrain part Gear Bicycle
I can't be rust because that's not a steel frame.
So I'll presume that's an aluminum frame. Salted water i.e., sweat or road spray, will penetrate small cracks in the paint. The aluminum will bubble on the surface but it won't structually damage or compromise the frame.
I doubt Specialized will warranty it; their view will be you failed to take care of the frame properly. And that's true; after those sweaty or salt-influenced rides, you HAVE to wipe the frame down with plain water. Trust me; as a long time steel frame owner, I've learned a lot.
I'd take it in to the shop where you purchased the bike and ask them. The frame is carbon, but the dropout is Al. My completely arbitrary (based on internet pictures) guess is that the joint is corroding between the two and failing. As long as your the original owner with proof of purchase, it never hurts to ask.
Even if they say it's paint failure and the warranty for paint was only one year, they are usually pretty good with offering 'crash replacements' where you can get a new frame at a steep discount if you turn in the damaged one.
I would agree with rcb78 assessment and have it looked at. If he's right, I would believe that joint is severely compromised and would deem it unsafe to ride.
I would be looking for a new bike frame, either paid by you or Specialized.
Cycling induced anoesis
... any ideas how Specialized would address this?
First off, do NOT ride that bike.
IMO, in order of likelihood...
1. They'll offer a crash replacement
2. They'll offer nothing
3. They'll warranty it
But the place to start is a Spec dealer.
Thanks all - it's not really what I wanted to hear but I suspected that might be the case. I'm off to see what the dealer says
When did an aluminum Roubaix come out? I must of missed that model.
I thought a couple years ago Specialized came out with their Smart Wall technology which was hydroformed aluminum. I could be wrong. I just assumed they were (still?) offering it.
Good call about the aluminum dropout bonded to the carbon. Yes, carbon will react with aluminum so there has to be an insulator between the two materials such as Kevlar fabric sleeving. Direct contact between the two could cause the result seen in the photos. I'd be curious to see if Specialized warranties that.
There were E5 Roubaix frames back in the early life of the model. The one in the picture clearly is not though, the dropout design is a dead giveaway. That said, the dropouts are Al moulded into the carbon tubing. I don't know how extensive the joint is though which is why he should get it looked at by a dealer.
Discussion Starter · #12 ·
Quick update if anyone is interested, my LBS has taken photos and a copy of the original receipt to send off to the Specialized rep on Monday. Stay tuned...
Peter P, it is a full carbon frame with alloy dropouts. I probably should have used "corroded" rather than "rust" in the initial post, sorry for the confusion
A curious thread. Can you tell us the history of the bike? Do you live near the ocean?
Most of us have never seen that level of corrosion on a Specialized Al bike.
Lastly, I wonder where you get the Roubaix name from? The bike you show is not a Specialized Roubaix FWIW. Perhaps the bike is an Al Roubaix from another brand.
If you insist the bike is a Specialized Roubaix, please post pictures showing the rest of the frameset to prove this. Only other wildcard if it is a Roubaix is...it maybe a very early example when the bike was created well over a decade ago.
Just curious, with a bold statement that it's not a Specialized Roubaix, what makes you think that with the pictures provided.
Just curious, not trying to poke the bear.
Forever a Student
Must be hard to live inside of your head.
I'll put some money down saying the OP is dead accurate and you're full of it.
Discussion Starter · #16 ·
Can you show us pictures of the bike?...and not just the drop out. Is that the factory paint job? Believe many here believes that's an Al bike. Perhaps it isn't. Most of us...me...have never seen a carbon bike...any bike...bubble like that.
Unless you show greater context, it isn't a stretch to incredulity to believe that isn't a carbon Roubaix. I own a 2012 carbon Roubaix SL3 Pro FWIW. I am very familiar with that bike.
Show us more pics. If the frameset is carbon and was repainted this may explain the bubbling...if the frame was contaminated when repainted. The carbon lay up may in fact be OK...or maybe not. Generally Al doesn't bubble aka rust either...more common with steel and that isn't a steel frameset because the downtube shown is too large in diameter. Show us pics of the 'bike'...as requested.
Some sort of Galvanic corrosion between carbon and alloy bonded components?
By the way, your cassette looks REALLY clean, were you spraying any sort of degreaser or anything onto that area of the bike that may have damaged the paint?
Discussion Starter · #19 ·
No degreaser, the cassette is brand new in the photo. I've actually just replaced the entire groupset with Ultegra 6800 as one of the original 10 speed shifters broke. Hence why I'll be a bit upset if the frame is no good.
11spd, it's not been repainted or crashed. I'm not sure why you're so suspicious. If you won't take me at my word I'll just say thanks thanks for your contribution to this point and leave it at that.
1 - 20 of 39 Posts
