1 - 20 of 32 Posts
Naso Unicornis
Hi Guys:
Last year, I purchased a 2015 Super Six Evo HM frameset. I could not install my previous BB30 Hollowgram SL crankset with the 102mm spindle as it was too short with the PF30 BB. I purchased a 109mm spindle, which comes standard with the SI SL2 crankset. Worked great!!! However.... A few month down the road and here comes SRAM ETap.
My drive side crankarm hit the front derailleur. Yeah, you read right, it it the friggin front derailleur as the body is considerably wider than my old mechanical SRAM Force derailleur.
Switched spacers that came with the 109mm spindle and the larger spacer is too wide. Installed 3 bearing covers and managed to get it working. I installed the smaller spacer and the wave washer on the non drive side of the BB.
Anyone run into this problem? Are the one piece spider that much thicker than the original first general spider?
CHL
Naso Unicornis
Made some more changes tonight, although minor. I had a lot of shims. On the drive side, I now use the 2-2.6mm (i forget the exact thickness) with six shims. On the non drive side, I have two shims and the wave washer. I really could use two more shims to achieve a better compression of the wave washer but I honestly, at this point, I'll settle for what works.
The derailleur has about 1.5-2.0mm clearance to the drive-side crankarm. Since I've shifted the axle to the left, I added a few shims to my non drive side pedal.
Shifting wise, I"m quite impressed with the speed and cleanliness of the shifts. I still think that a properly tuned mechanical will give electronics competition but I need to put serious miles on the group before forming a valid evaluation of the group. Lucky for me the Santa Cruz Mountains Challenge is around the corner. 100 Miles with 11K of elevation should be a nice test bed.
LA CHEVRE
Looking at the eTap front derailleur, I see what you mean. The outside swing link between the main body and the cage sticks out a bit more than other front derailleurs...
Interestingly, all the Cannondale 2017 models that are specs with eTap are not built with Hollowgrams but with SRAM Red cranksets. At first I thought it was due to SRAM only selling eTap as a whole to OEM (that's what they did at first with their Eagle XX1 MTB group) but maybe it's because of that clearance... Hollowgram arms are quite thick.
I'm looking into getting an Evo Disc with eTap but wanted to put a Hollowgram SISL2...
OK so I asked him. It looks like it was pretty straight forward when he switched his crank. No additional shims needed for the CAAD12.
Thats my Caad12 you are refering too. Used a SL crank though. So maybe the siSL2 has different arm shapes. Sounds like the case. Heres my clearance with SL arms and a diagram of the exact spacers and shims, all stock. Sorry for the crappy pics, but you can see the spacing...
Naso Unicornis
Discussion Starter · #8 ·
I wonder if it could be the derailleur hanger. There is a triangular shim that you install behind the body of the front derailleur, that is afixed with a 2mm hex bolt. I use the largest shim provided by SRAM. I wonder which size shim you use with your CAAD12 frame.
Also saw a Super Six DI2 edition today. The bike had the stock Hollowgram SL2 with stock hardware. The DI2 Derailleur had Huge amount of clearance with the crank arm.
CHL
I used the smallest shim. Although the derailleur is fixed and the shim was meant so theres no flex from the slight gap in the bottom. At least thats how I understand it. You torqued the crank arms with a torque wrench to the proper torque spec? Theres no play in the spindle is there?
Sorry about my last response. I miss read your post. I thought you were using the SiSL2 arms. You should have it setup exactly like the diagram. They do say for non drive side you can use up to three plastic shims (.5mm). But you need to use the 2.5mm spacer on the non drive side, not the larger spacer that was used for standard BB30. But the drive side only has the 2.5mm spacer and bearing cover.
LA CHEVRE
There is a slight difference in arms shape between the old SL and newer SISL2 and 3D-forged SI. The new ones have a small taper on the inside of the arms at the pedal ends, so theorically, they should have more clearance but only near the end, the taper is small.
Other than that, using an old SL crankset but with the newer 109mm spindle, you get a wider q-factor but mostly on the non-drive-side. The drive-side arms have the same geometry new and old, but the new non-drive-side arms don't extend as much 'outside' as the old one so the new arms on new 109mm spindles has the same q-factor and centered stance as the old setup. But old arms on a new spindle with spacers installed as the manual states will make the q-factor 5mm wider but that 5mm movement will be mostly on the non-drive-side so the stance wont be centered anymore. But given the new spindle has no built-in lip, you could easily center the stance by having more spacers on the drive-side and less non-drive-side compared to the manual, and that would also add clearance for the eTap front derailleur... but your feet will be spaced 5mm further apart still.
Does that make sense? :D
Regarding other front derailleurs than SRAM eTap, no issues. Di2, Shimano mechanical, SRAM Red mechanical, Campy... they all have enough clearance and work with Hollowgrams. The particularity of eTap is that, when shifted on the big ring, the cage's outer plate is not the point that sticks out the most as is the case with other derailleurs, it's the swing link part just above the cage itself that sticks further out...
LA CHEVRE
Oh and, CHL, the SpideRing doesn't change anything at the BB, same width as the 5 bolt spiders. But, when Cannondale introduced the Evo and switched to PF30, they changed the shape of the spider's lockring as the old one didn't fit with the PF30 cups that extend a little outside the frame's BB shell... but now that you have a 109mm spindle, the lockring doesn't matter.
Naso Unicornis
Discussion Starter · #13 ·
Dan:
Did you have to modify the installation in any way or is complete stock on the drive side (2.5mm spacer only).
Also, how does it shift with the Cannondale chainrings?
Thanks,
chl
I had the eTap installed last week. No issues on my CAAD12 as well.
Shifting was great and no chain rub on BIG-BIG, BIG-SMALL, etc. compared to my mechanical Ultegra. Using KMC chain + DuraAce 12-28.
Naso Unicornis
Discussion Starter · #16 ·
How much clearance do you have between the front derailleur outer cage, the swing arm of the front derailleur and crank arm? On my SS6 EVO HM, I probably have 1mm perhaps on both (crank arm to swing arm and derailleur cage).
I looked at my Slice with a SRAM Red 10 Speed Crankset (105 front derailleur) and I have lots, I think at at close to a 1cm.
You have no chain rub in small chainring/small cogset? BTW, looks like!!!
CHL
OK so I checked. I do have a rub SMALL-SMALL. It's just that I never used that combo so I made a blanket statement. My clearance is approx close to 1.5mm (used an allen wrench) with FD at the big ring. It's from the crank arm to the first/top limit screw that protrudes from the FD.
I have just installed an eTap mini group in my Cannondale and also got the same clearance issue with Hollowgram crank arm - check pic attached, I got 1mm max.
Nevertheless, I tried yesterday and shifting was very good. No rubbing after 1st ride...
But it is so close I guess it will eventually touch, so I am after a new pair of shorter limit screws.
Anyone can help me finding a supplier for these screws, or a contact in US who might have it?
I am afraid to move forward with any grinding... never done it before.
My bike is an Evo 2012 with SL cranks with Compact Spider rings (50t-34t)
Will e-tap works ?
Thanks
I guess so, but I think you are going to have the same issue of minimal to none clearance between right crank arm and FD limit screws.
When you buy eTap make sure to get the shorter limit screws - and please let me know where you found them :) I am still seeking...
1 - 20 of 32 Posts
