I doesn't even look like it will work on the 2nd big cog. What does it look like when you put the scam in the littlest cog RD position, is it way off the cassette on that side?
Yea its off by a cog to the right of the smallest cog. Im wondering if i got a bunk derailleur somehow. Its just weird that it will row the gears properly but offset by so much. Maybe thats why it was for ssle. I put my kit together piece by pieceI doesn't even look like it will work on the 2nd big cog. What does it look like when you put the scam in the littlest cog RD position, is it way off the cassette on that side?
Given the upper-pulley's axis is far off from that of the cassette....either the hanger is still way out, or the RD cage is bent. I also wonder about needing literally all the b-screwYour RD hanger may be aligned, but it sounds like it is setup way right. I would take it off and beat it straight, then realign. It may be the wrong hanger.
Yea, that's a WIFLI RD. Which can take up to a 32-tooth cog. The B-screw is maxed out and still not close to clearing the 28T cog.I also wonder about needing literally all the b-screw
