I recently bought a lightly used 2018 Supersix (non-Hi-Mod) with Dura Ace 9100 (rim brake with Dura Ace 9100 calipers), 50cm frame size. The rims, which are stock, are "Cannondale HollowGram Si Carbon Clincher, 17mm inner, 35mm deep" (I am quoting from the 2018 catalog verbatim). The spoke count is 18 front and 24 rear. The current tires are Bontrager R3 25c and I've had no problems in terms of fit. (The catalog says the original tires were Vittoria Corsa 25c)
I just ordered a pair of Continental GP5000 28c tires. Did I make a mistake? I've read on various forums that some people have said 2016-2018 Supersix rim brake versions will fit a 28c tire no problem-- but it also depends on the rim brake model (SRAM brakes not having enough clearance, but I have Dura Ace 9100). And I also read that spoke count on the rims make a difference and that lower spoke count will present issues--not sure on the reasons (perhaps the higher spoke count cause less flex and thus tire won't deflect into chainstays or brakepads??). I also see that some people have used 28c on the front and 25c on the back, but I want to be consistent.
Anyone who has been able to run the 2016-2018 SuperSix rim brake with this rim with 28c tires? I attach a photo of my bike below (excuse the excess steerer tube which is going to get cut soon!). Thanks!
