Bike has a good few miles on it, I just have no use for it. Shimano Groupset, Manitou Machete Comp 110mm fork upgraded, and Bontragor Chupacabra 3” tires.
Frame has some scratches/blemishes from poor transportation. Just tuned up at the end of last season so it’s ready to ride. Will come with brand new pedals & Ergon GP1 grips
Specifications;
Product Trek Stache 5 Bike
Model Year 2019
Riding Type Cross Country
Rider Unisex
Size 17.5 in
Wheel Size 29+
Frame Material Aluminum
Frame Material Details Alpha Platinum aluminum, midstay design, internal cable routing
Rear Travel Hardtail
Rear Shock N/A
Fork Manitou Machete 32 Comp, air spring, ABS damper, lockout, Boost110, 51mm offset
Fork Travel 120mm
Head Tube Diameter Tapered
Headset FSA IS-2
Handlebar Bontrager alloy, 31.8mm, 15mm rise, 750mm width
Stem Bontrager Rhythm Comp, 31.8mm clamp, 0 degree
Grips Bontrager XR Trail Comp, nylon lock-on
Brakes Shimano MT200 hydraulic disc
Brake Levers Shimano MT200
Drivetrain 1x
Shifters Shimano Deore M6000, 10-speed
Front Derailleur N/A
Rear Derailleur Shimano Deore M6000, Shadow Plus
ISCG Tabs No
Chainguide No
Cranks FSA Gamma Pro
Chainrings 28 tooth
Bottom Bracket PF92
Chain KMC X10
Cassette Shimano HG50, 11-42 tooth, 10-speed
Rims SUNringlé Duroc 50 SL, 28 hole, tubeless strips and valves included
Hubs Bontrager alloy, Boost110 front, Boost148 rear
Spokes
Tires Bontrager XR2 Team Issue, tubeless ready, 120 tpi, aramid bead, 29 x 3.00˝
Saddle Bontrager Arvada
Seatpost Bontrager Dropper, internal routing
Seatpost Diameter 31.6mm
Seatpost Clamp Standard single bolt
Rear Dropout / Hub Dimensions Boost148
