1 - 1 of 1 Posts
Purchased new 1st May 2020 - carbon frame (medium)
Excellent condition. Maintained to the highest standards. After every outing, it is hand washed, blown dry with an airline, oil-lubed and adjustments made (where applicable). The bike has the usual wear marks in places where shoes, clothing etc rub, but not damage or scratches. Extra bits on bike and spare tyres.
Spec
FOX FLOAT DPX2 Performance Elite (Length: 230 x 60 mm)
FOX 36 Performance Elite
• Travel: 160 mm
• Technology: FIT4
• Axle Dimension: 15 x 110 mm
Rear Derailleur
• Shimano Deore XT, 12-speed
• 12-speed, max cassette size: 51T. Weight: 282 g, Shadow RD+ chain stabilizing system
Chain guide MRP V2 ISCG
Shift Lever - SRAM MMX XO1 - Clamp: MMX
Shift Lever
• Rear derailleur shifter, 12-speed, Textured rubber lever pad, Multi-Release, 2-way release, I-Spec EV clamp allows 14mm lateral adjustment and 20-degrees rotation adjustment, 130 g
Cassette
• Shimano SLX, 12-speed (10-51)
• Primarily-steel cogs with aluminium 51T cog, Microspline interface, Gear range: 10-51T, weight: 533 g, Hyperglide+ technology provides better chain engagement
Crank
• Shimano Deore XT M8100 32T
• Shimano XT crankset sports a 32-tooth chainring and 170mm crankarms for optimal pedaling clearance.
Bottom bracket
• Shimano MT800, Threaded
• Hassle-free Shimano Hollowtech II threaded bottom bracket
Chain
• Shimano CN-M7100 12s
Disc Brake
• Shimano XT 4-piston front brake
• High-power 4-piston brake, reach adjust, quick pad retraction, banjo-type connection, ICE TECH brake pads, 410 g
Disc Brake
• Shimano XT 4-piston rear brake
Brake Rotor
• Shimano RT86, 180mm
• 180mm Shimano RT86 rotor provides a good balance of stopping power and modulation.
Wheel
• DT Swiss E 1700
• Rim Material: Aluminium
• Inner Width: 30 mm
• Weight: 947 g
Wheel
• DT Swiss E 1700 SH12
• Inner Width: 25 mm
• Freewheel: Ratchet
Tyres – comes with spare set of MAXXIS Minion DHR II 2.4''
Pedals – Crank Brothers Stamp 7 platform - Danny MacAskill edition
Seatpost
• FOX Transfer Performance Elite
Handlebar
• Canyon G5 Riserbar
• Our aluminum G5 Riser bar offers the perfect combination of width (780mm) and rise (30mm).
Bar stem - Renthal
Saddle
• SDG Radar
Price: $3500
478615
1 - 1 of 1 Posts
