21 - 40 of 52 Posts
Discussion Starter · #22 ·
Wow... now that's gravel riding! Where's the nearest coffee shop? :confused:
None on that particular route. It's pretty much all Cleveland National Forest.
Good coffee in OC though. Scouting some more urban/mixed gravel routes for a ride I want to put on. Start/finishes at a brewpub with 40 taps, french bakery at halfway point. Should be fun.
Discussion Starter · #25 ·
Terrain Enve! Where is this, looks awesome!
4000 to 6,000 ft range about 20 miles inland, southern California. Eastern border of Orange county. I live and work at the base of the Western slope. In the distance is the 1500 ft coastal range where I rode the Domane yesterday. Spectacular panorama's of the hazy blue Pacific. Tough living but someone has to do it :)
Discussion Starter · #27 ·
Thanks
Single, no kids, prime earning years. I'd rather have a wife and kids but that never worked out. So now I have time to train and a few bucks to spend on toys :)
Nice looking bike. I'm curious, do you also have a road bike? If so, how does this compare in terms of the size you selected? Did you go for the same top tube length as your roadie or something different? I'm planning on building a gravel rig this year. My two road bikes have 575mm top tubes. Not sure if I want the same size or not. I've heard some people go down a size for gravel and CX for a little more agility and standover room. TIA.
Discussion Starter · #29 · (Edited)
Top tube is a useful reference point but what I look for is reach and stack. The height of my bars relative to the bottom bracket between my road and cross bikes is significant, ~60 mm or so. My goal with the Domane was to be about 30mm above my road bike bar height. My Cervelo S5 disc is very low in front, focused on aero. Fore-aft reach, I was aiming for about 10 mm closer than the reach on my S5. Those targets were impossible with the standard Domane geometry but fit perfectly with the optional Pro geometry.
My cross bikes are shorter reach and taller bar height. Make sure you have measurements for the relationship between the bottom bracket centerline of the bars and seat. Then your relationship from the seat to the wheelbase will dictate weight distribution and how the bike handles. I did not intentionally choose a smaller frame for handling.
Top tubes tend to be longer and stems shorter for gravel bikes ... the overall reach to the bars is basically the same, but the center of gravity is different on gravel bikes.
I wouldn't use the same geometry as your road bike ... but look at what should be considered an equal size gravel bike for your size road bike ... so, S/M/L/XL, etc. figure out what those dimensions are and go from there.
If you don't know ... test ride, test ride, test ride.
Myself ... My set up is similar to that of my road bikes, however the reach is 1cm longer and the stem 1cm shorter. I'd prefer to have 2-3cm more reach in the frame with a shorter stem ... but I have a weird fit with long arms and body and short legs: If I get a bike with the correct reach, I can't stand over it and the bar is "WAY' to tall, so I have to size down 1-2 sizes and make it work.
I have also eliminated all my road bikes now and just have my gravel bike with an extra set of wheels so I can switch out between road and gravel tires easily ... works just fine, but being on a 1x drivetrain the gaps can be a little large on the road, but not a huge deal overall since I'm not road racing any longer.
Discussion Starter · #31 ·
Update after a few thousand miles of mostly offroad use. Had the nuts that hold the isospeed trunion in place come loose. Misdiagnosed as a loose headset so I rode on it for a while that way. Doh. Thankfully, the nuts (#22 in schematic) have a conical versus shank seat design. So the bosses in the frame weren't ovalized. A bit of tiny carbon fragments but I escaped a major frame repair. The nuts have an integral eccentric washer that keeps them from spinning as you turn the center bolt (#21) to torque down. The nuts were blue loctited from the factory. Cleaned and red loctited, then probably over torqued a wee bit. No play, all good now. The bolts on my Boone with front isospeed never came loose with maybe 3x the miles and a bunch of cross races. Maybe a different fastener design on the '18 Boone, dunno
So if you have a 2020 Domane and ride it off road, might not be a bad idea to preemptively pull those fasteners and red loctite them to factory torque spec.
Text White Line Font Parallel
Discussion Starter · #32 ·
Just saw this tread , some good info Emilio. And nice to finally see someone on this forum with the physical flexibility to set the bar/ stem height, in a similar fashion as me.
After all, performance is comfort.
LOL you get it! ... fitness, flexibility, and bike fit; all come together to enhance performance. And comfort is the sum total.
It doesn't work the other way around.
I'm strictly on the road, Giant TRC, and winter/wet bike BMC RoadMachine.
Both bikes kick ass.
21 - 40 of 52 Posts
