1 - 5 of 5 Posts
I just wanted to get some feeback from anyone who has had experience with both of these rims in regards to spoke count. I am building up a custom wheelset as an all rounder with White Ind H2 hubs and Kinlin Niobium clincher rims. I am 190 lbs, 188cm tall and do about 300k a week.
My question is the durability of the 27mm over the 30mm. I was first looking at the 30mm with a 24/28 2 cross all round. I like the look of the 27mm rims with the added benefit of saving some valuable grams but should I up the spoke count?
Cheers
Both rims are fine. The 27s are a little wider... which is nice. If you use heavier spokes (2.0/1.7-1.8mm) on the DS rear (at least), then 24f and 28r should be ok.
Your body weighs over 86,000 grams... so keep this in mind while sweating 40g on your wheels.
ruff do you have have the real widths for the 27& 22 rims l have a 30mm rear laced to a pt hub and would like to build a front as well out of the these two, btw are they measured
from inside or outside of the brake track? Thanks
Brian.
1 - 5 of 5 Posts
