1 - 6 of 6 Posts
I picked up some continental 4000s 28s for my bike. Bike is 2015 specialized roubaix sl4 with axis 1.0 brakes. Are there any brakes that would prevent me having to deflate the tube to take on and off. Once you get it on, it has proper clearance but getting on and off is the issue. I read reviews on Shimano 105 brakes and the description says fits 28 tires.....does this mean I wouldn't have to deflate? Any brake that could help would be better.
Banned Sock Puppet
I have used Shimano 105 brake calipers with 28c tires and never had to deflate tires to get the wheels off. I'm also pretty sure you will notice improved modulation over the stock Axis 1.0 calipers.
How close to the rim do you have the pads set? Some people set them much closer to the rim than necessary, which makes it hard to remove the wheel and also makes for poorer brake modulation because you have to brake with your finger tips on the levers.
Banned Sock Puppet
Most bikes come from the factory with the pads set too close to the rims.
CX'er
Keep in mind, conti GP 4000's tend to measure a little larger than advertised so it may not fit right in. However, I haven't had trouble with the conti's, or any 28mm tires, with sram red brake calipers and I assume shimano allow similar widths of tires when opened.
1 - 6 of 6 Posts
