1 - 5 of 5 Posts
The Edge
tantra said:
Does anyone know if I could fit Conti GP 28C tires on a CAAD9 5 frame? How about GP 25C tires?
You can, but be careful. I did the same thing and after 2000 miles something happened to my rear tire and it started to rub the rear brake bridge.
Got a ruler?
Just measure it. If you currently have 23 mm tires on and you want to increase to 28, then you need at least 5 mm clearance between the tire and the fork crown or brake bridge. Recognize that: 1) that is the minimum clearance snd 2) not all tires are the same size as the label says.
1 - 5 of 5 Posts
